Thread: Knock Retard when accelerating
Results 21 to 40 of 41
  1. #21 Re: Knock Retard when accelerating
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    also.. just so you know matt. i borrowed my buddies efi live and used the pcm you said since it doesn't have one specific for our cars. the scanner read 0 on about five runs.. and about 4-7 on a few other runs. than the next day i got it scanned with the hptuners for our cars.. and was runnin a consistent 5 kr every time we ran it.. about ten times.. so i would take what that efi live says with a grain of salt. not knockin efi live as it's a great program... but not specific for our cars!!
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  2. #22 Re: Knock Retard when accelerating
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    does the fact your running a DHP v1 PCM with a stock pulley mean anything?!?
    cuz according to 3800perf.....
    "Developed with the average 3800 enthusiast in mind, this calibration has been designed and dynamometer tested and proven for the following vehicle modifications installed:
    - 3.4” - 3.20” pulley
    - Cold air induction system (brand not applicable)
    - Cat-back exhaust system (brand not applicable)
    - Premium fuel (91+ octane)
    *NOTE: This calibration is NOT intended for stock 3800 powered vehicles. Additionally, premium fuel IS required."
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  3. #23 Re: Knock Retard when accelerating
    ^^ DONT EVER...
    Post that. Those things are YEARS old. Follow the Safely Modding Your 3800 Thread.
  4. #24 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I've tried a few more things, and am still getting nowhere with this problem. Anytime I go into boost and am up around 100 in the MAP readings, I get way too much knock retard.
    -dealership fuel injector drop test: no problems found (p0420 code somehow hasn't returned since this)
    -compression test: all good at 180 lbs. in all cylinders
    -MAF tuning: No Effect
    Here is a current scan (no wot) that shows if I push the pedal down even just a little too hard, KR is there to remind me:
    2210 from xxrzdxx -- Scan Depot dot net
    Some of the scan is while waiting on drive-thru, but it is there in hopes someone can also identify the occasional sputter/vibration during idle. Scan was made with the Powertuner this time.
    I really don't know what else there is to do, that I haven't done already...besides having to drive around like an old lady.
  5. #25 Re: Knock Retard when accelerating
    to be honest i dont see much in the scan that would point towards why youre knocking so much. it seems as though the boost and KR are constant with eachother for some reason.
    maybe its possible you have the exact opposite of a freak? maybe you need a butt load more mods?
  6. #26 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I haven't always had these type of scans, it's only been for about a year or so now.
  7. #27 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Try gradually rolling through the throttle, or more slowly. Its harder to pinpoint anything when its just a couple blips or jumps of KR. I'll look at it more later...
  8. #28 Re: Knock Retard when accelerating
    Fort Wayne, IN
    As requested, here's a new one with a more gradual climb:
    AccelGrad2410 from xxrzdxx -- Scan Depot dot net
    Something that I have noticed in all my scans is that at the suggested PE enable point at around 100kpa on the MAP, I always hit this mark at only 20% throttle. While everyone else I've noticed seems to be more in the 30% percent range. With stock being around 40-45% throttle.
    I do know that my LIM is leaking some oil where one of the larger gasket portions meets one of the small, rail type portion of the gasket. I don't think the dab of sealant at that point was applied right, when they were replaced. This is the meeting point near the 6th cylinder. I cannot detect any vacuum leaks, and is only leaking oil to my knowledge. Wanted to throw that in there in case there's a possibility it is related.
    I do plan on running a fuel injector and then air intake cleaner through the top end this weekend, with the pressurized canister tool.
  9. #29 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Do you have the powrtuner or who is tuning it, what programs are you using for tuning? I don't see any 02's get past 900 on the narrowband in that scan but your also not entering PE that much. You must have PE afr at 11.5 or so? I would try adding 10% on the maf table from 6000 on up and smooth that out. Wait til the fuel trims settle back down and then post a scan again. See if a larger change in the fueling will alter the kr any. What is your PE enable tps at? Here is what mine is set at, but you can probably go a tad higher since your s/c.
    Fuel -> PE -> PE Enable TPS
    File Location: C:\Documents and Settings\Administrator\Desktop\BINS\2kturboE85roun d6.bin
    Percent
    RPM 0 40
    400 40
    800 40
    1200 35
    1600 35
    2000 31.99219
    2400 30
    2800 25
    3200 20
    3600 20
    4000 20
    4400 20
    4800 20
    5200 20
    5600 20
    6000 20
    6400 20
  10. #30 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I have the Powertuner, but have put everything except for transmission settings back to stock. I've decided that my car is mostly stock and I could see maybe having to tune out 2-3 degrees of knock, but there is no reason for 7*+ on my setup without something being wrong mechanically.
  11. #31 Re: Knock Retard when accelerating
    Fort Wayne, IN
    Well, intake system cleaner had no effect whatsoever.
  12. #32 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Did you try adding 10% to the maf table at 6000 and up? I would also play with the AE table to see if it will do anything. Your narrowband readings could make it look like its just fine, but it is not very accurate.
  13. #33 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I added 10% to everything above 6000 with PE enable mostly at 30%, and got the highest KR numbers I have ever had...12 degrees on the highway at about 85% throttle. Somehow these setting had the opposite of the desired effect.
  14. #34 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by xxmattfxx View Post
    Did you let the fuel trims settle back down before scanning or WOT? If the ltft's are still learning the trims again, it will not lock in at 0 and will cause the fueling to be off until they are relearned. If you did all that and still got the kr, try the opposite, take away 10%.
  15. #35 Re: Knock Retard when accelerating
    SE Level Member rah575554eg's Avatar
    Apr 2009
    Alliance, NE
    What I can tell you from experience that the misfiring and KR is probably coming from an intake leak. On my 03 GTP it was misfiring on the number four cylinder and sure enough it was an intake leak. That's something to look at. I hope that helps you! Good luck!
  16. #36 Re: Knock Retard when accelerating
    Fort Wayne, IN
    Wanted to report back on my recent findings.
    On a hunch, mainly from the ticking when first started, I had been off and on checking for exaust smoke at the rear of the engine but could never spot anything. I read somewhere about holding a tissue around the suspected area, I at first I didn't notice anything, until I lowered it far enough to reach the bottom of the exhaust manifold and sure enough the end of the tissue started moving with the RPMs. This, I assume, would explain the 30*+ IAT readings over ambient with the stock airbox. New exhaust manifold and gaskets are on there way. I don't know for sure right now if the gasket is bad, or if there is a crack inthe manifold, but I only want to do this once. This hopefully is the root of all my problems, but if not, it is at least the root of some of them.
  17. #37 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Well if its a bad enough leak, it can throw your 02's off. Fix it, return the MAF table to stock settings, re-tune.
  18. #38 Re: Knock Retard when accelerating
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Thank you for the tip about using tissue. I will try it. Did your exhaust issue resolve your other performance /KR condition?
  19. #39 Re: Knock Retard when accelerating
    Western New York
    the vibration dampner spun , thus throwing vibrations thru sensors which is affecting pcm
  20. #40 Re: Knock Retard when accelerating
    Quote Originally Posted by Seansta View Post
    Wut.
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  3. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
  4. Weird Whine When Accelerating
    By angelamarie990 in forum General Tech Discussion
    Last Post: 04-08-2009, 10:30 PM
  5. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
