Thread: Knock Retard when accelerating
Results 1 to 20 of 41
  1. #1 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Try gradually rolling through the throttle, or more slowly. Its harder to pinpoint anything when its just a couple blips or jumps of KR. I'll look at it more later...
  2. #2 Re: Knock Retard when accelerating
    Fort Wayne, IN
    As requested, here's a new one with a more gradual climb:
    AccelGrad2410 from xxrzdxx -- Scan Depot dot net
    Something that I have noticed in all my scans is that at the suggested PE enable point at around 100kpa on the MAP, I always hit this mark at only 20% throttle. While everyone else I've noticed seems to be more in the 30% percent range. With stock being around 40-45% throttle.
    I do know that my LIM is leaking some oil where one of the larger gasket portions meets one of the small, rail type portion of the gasket. I don't think the dab of sealant at that point was applied right, when they were replaced. This is the meeting point near the 6th cylinder. I cannot detect any vacuum leaks, and is only leaking oil to my knowledge. Wanted to throw that in there in case there's a possibility it is related.
    I do plan on running a fuel injector and then air intake cleaner through the top end this weekend, with the pressurized canister tool.
  3. #3 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Do you have the powrtuner or who is tuning it, what programs are you using for tuning? I don't see any 02's get past 900 on the narrowband in that scan but your also not entering PE that much. You must have PE afr at 11.5 or so? I would try adding 10% on the maf table from 6000 on up and smooth that out. Wait til the fuel trims settle back down and then post a scan again. See if a larger change in the fueling will alter the kr any. What is your PE enable tps at? Here is what mine is set at, but you can probably go a tad higher since your s/c.
    Fuel -> PE -> PE Enable TPS
    File Location: C:\Documents and Settings\Administrator\Desktop\BINS\2kturboE85roun d6.bin
    Percent
    RPM 0 40
    400 40
    800 40
    1200 35
    1600 35
    2000 31.99219
    2400 30
    2800 25
    3200 20
    3600 20
    4000 20
    4400 20
    4800 20
    5200 20
    5600 20
    6000 20
    6400 20
  4. #4 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I have the Powertuner, but have put everything except for transmission settings back to stock. I've decided that my car is mostly stock and I could see maybe having to tune out 2-3 degrees of knock, but there is no reason for 7*+ on my setup without something being wrong mechanically.
  5. #5 Re: Knock Retard when accelerating
    Fort Wayne, IN
    Well, intake system cleaner had no effect whatsoever.
  6. #6 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Did you try adding 10% to the maf table at 6000 and up? I would also play with the AE table to see if it will do anything. Your narrowband readings could make it look like its just fine, but it is not very accurate.
  7. #7 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I added 10% to everything above 6000 with PE enable mostly at 30%, and got the highest KR numbers I have ever had...12 degrees on the highway at about 85% throttle. Somehow these setting had the opposite of the desired effect.
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  3. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
  4. Weird Whine When Accelerating
    By angelamarie990 in forum General Tech Discussion
    Last Post: 04-08-2009, 10:30 PM
  5. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
