Thread: Knock Retard when accelerating
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 41
  1. #1 Re: Knock Retard when accelerating
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    also.. just so you know matt. i borrowed my buddies efi live and used the pcm you said since it doesn't have one specific for our cars. the scanner read 0 on about five runs.. and about 4-7 on a few other runs. than the next day i got it scanned with the hptuners for our cars.. and was runnin a consistent 5 kr every time we ran it.. about ten times.. so i would take what that efi live says with a grain of salt. not knockin efi live as it's a great program... but not specific for our cars!!
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  2. #2 Re: Knock Retard when accelerating
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    does the fact your running a DHP v1 PCM with a stock pulley mean anything?!?
    cuz according to 3800perf.....
    "Developed with the average 3800 enthusiast in mind, this calibration has been designed and dynamometer tested and proven for the following vehicle modifications installed:
    - 3.4” - 3.20” pulley
    - Cold air induction system (brand not applicable)
    - Cat-back exhaust system (brand not applicable)
    - Premium fuel (91+ octane)
    *NOTE: This calibration is NOT intended for stock 3800 powered vehicles. Additionally, premium fuel IS required."
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  3. #3 Re: Knock Retard when accelerating
    ^^ DONT EVER...
    Post that. Those things are YEARS old. Follow the Safely Modding Your 3800 Thread.
  4. #4 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I've tried a few more things, and am still getting nowhere with this problem. Anytime I go into boost and am up around 100 in the MAP readings, I get way too much knock retard.
    -dealership fuel injector drop test: no problems found (p0420 code somehow hasn't returned since this)
    -compression test: all good at 180 lbs. in all cylinders
    -MAF tuning: No Effect
    Here is a current scan (no wot) that shows if I push the pedal down even just a little too hard, KR is there to remind me:
    2210 from xxrzdxx -- Scan Depot dot net
    Some of the scan is while waiting on drive-thru, but it is there in hopes someone can also identify the occasional sputter/vibration during idle. Scan was made with the Powertuner this time.
    I really don't know what else there is to do, that I haven't done already...besides having to drive around like an old lady.
  5. #5 Re: Knock Retard when accelerating
    to be honest i dont see much in the scan that would point towards why youre knocking so much. it seems as though the boost and KR are constant with eachother for some reason.
    maybe its possible you have the exact opposite of a freak? maybe you need a butt load more mods?
  6. #6 Re: Knock Retard when accelerating
    Fort Wayne, IN
    I haven't always had these type of scans, it's only been for about a year or so now.
  7. #7 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Try gradually rolling through the throttle, or more slowly. Its harder to pinpoint anything when its just a couple blips or jumps of KR. I'll look at it more later...
  8. #8 Re: Knock Retard when accelerating
    Fort Wayne, IN
    As requested, here's a new one with a more gradual climb:
    AccelGrad2410 from xxrzdxx -- Scan Depot dot net
    Something that I have noticed in all my scans is that at the suggested PE enable point at around 100kpa on the MAP, I always hit this mark at only 20% throttle. While everyone else I've noticed seems to be more in the 30% percent range. With stock being around 40-45% throttle.
    I do know that my LIM is leaking some oil where one of the larger gasket portions meets one of the small, rail type portion of the gasket. I don't think the dab of sealant at that point was applied right, when they were replaced. This is the meeting point near the 6th cylinder. I cannot detect any vacuum leaks, and is only leaking oil to my knowledge. Wanted to throw that in there in case there's a possibility it is related.
    I do plan on running a fuel injector and then air intake cleaner through the top end this weekend, with the pressurized canister tool.
  9. #9 Re: Knock Retard when accelerating
    Jan 1970
    Maquoketa, Iowa
    Do you have the powrtuner or who is tuning it, what programs are you using for tuning? I don't see any 02's get past 900 on the narrowband in that scan but your also not entering PE that much. You must have PE afr at 11.5 or so? I would try adding 10% on the maf table from 6000 on up and smooth that out. Wait til the fuel trims settle back down and then post a scan again. See if a larger change in the fueling will alter the kr any. What is your PE enable tps at? Here is what mine is set at, but you can probably go a tad higher since your s/c.
    Fuel -> PE -> PE Enable TPS
    File Location: C:\Documents and Settings\Administrator\Desktop\BINS\2kturboE85roun d6.bin
    Percent
    RPM 0 40
    400 40
    800 40
    1200 35
    1600 35
    2000 31.99219
    2400 30
    2800 25
    3200 20
    3600 20
    4000 20
    4400 20
    4800 20
    5200 20
    5600 20
    6000 20
    6400 20
  10. #10 Re: Knock Retard when accelerating
    Western New York
    the vibration dampner spun , thus throwing vibrations thru sensors which is affecting pcm
  11. #11 Re: Knock Retard when accelerating
    Quote Originally Posted by Seansta View Post
    Wut.
  12. #12 Re: Knock Retard when accelerating
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    LOL!
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  3. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
  4. Weird Whine When Accelerating
    By angelamarie990 in forum General Tech Discussion
    Last Post: 04-08-2009, 10:30 PM
  5. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
