Thread: plug recirc. valve?
Results 1 to 10 of 10
  1. #1 plug recirc. valve?
    Tn
    I decided attempt to make my own intake. There is a little valve right after the throttle body. Do I need to make a hole in the intake for this or can I plug it.
    Car is an 07 Grand Prix GT.
    Thanks for any help
    Dustin
  2. #2 Re: plug recirc. valve?
    ...valve after the throttle body? your MAF? the IAT sensor?
  3. #3 Re: plug recirc. valve?
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    hell....all the valves r right atfter the throttle body lol take a pic and post it
  4. #4 Re: plug recirc. valve?
    SE Level Member GeeBee's Avatar
    Iowa
    Valve right after throttle body.....on a GTP thats the EGR butterfly right?
    2006 Grand Prix Gt - Wizair, Solid Poly Mounts
    1996 Olds 98 Regency Elite - Dieing of Car Cancer and old age.
  5. #5 Re: plug recirc. valve?
    Tn
    Heres a pic. I can easily tap into the intake or plug it. So either solution I get is fine with me. Thanks for the quick replies.
  6. #6 Re: plug recirc. valve?
    ... is that? where does it go? what is it connected to?
  7. #7 Re: plug recirc. valve?
    Iowa
    Thats the vacuum for the L32 m8
  8. #8 Re: plug recirc. valve?
    well, i realize its a vacuum line, but which one? im not used to the l32 throttle body setup.
  9. #9 Re: plug recirc. valve?
    Iowa
    Dunno but its not a recirc valve and prolly shouldnt be blocked off.
  10. #10 Re: plug recirc. valve?
    Tn
    I ended up tapping it back into the intake. It runs fine with it out and with it back in. It was under vacuum at idle so I figured it was best put back like the factory had it. Thanks for the replys
  1. plug gap
    Last Post: 08-10-2009, 02:44 AM
  2. plug gap
    By NoTyme in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 06:11 PM
  3. Which Plug should i go with ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2009, 04:57 PM
  4. I need this plug....
    By duane9586 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2008, 04:12 PM
  5. Anyone know where this plug goes/what it is???
    By LowlyfeGTP in forum General Tech Discussion
    Last Post: 01-23-2008, 04:35 AM
