Thread: Car Stalling Question
Results 1 to 4 of 4
  1. #1 Car Stalling Question
    utah
    Hey all, Ive been around the forum for a little while but this is the first time I have asked anything here.
    Basically I have a 99 GTP 3.8 S/C and when I start it up I have to give it some gas to get going. If I dont pump on the gas at the initial startup it wont start. Sometimes (like once every few weeks) Ill attempt to start the car and even after pumping the accelerator it wont start. After about 5 minutes minutes it will finally kick in.
    I thought it might be a fuel filter clogged but even after changing that it still does this...Could this be dirty injectors or my guess is fuel pump?
    Thanks all!
  2. #2 Re: Car Stalling Question
  3. #3 Re: Car Stalling Question
    utah
    thanks a bunch..ill try the relay first!
  4. #4 Re: Car Stalling Question
    Wausau, WI
    bend the tab on the relay.....see if that works
  1. stalling 99
    By kent jordan in forum General Tech Discussion
    Last Post: 05-02-2009, 11:40 PM
  2. In need of serious help with my car stalling
    By knightriider in forum General Tech Discussion
    Last Post: 03-13-2009, 01:24 AM
  3. stalling
    By gnjim in forum General Tech Discussion
    Last Post: 01-04-2009, 11:47 AM
  4. Car keeps stalling out
    By SD GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 07:43 PM
  5. another GTP stalling out sometimes
    By daryls377 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2008, 07:42 AM
