Thread: SC problem :S
Results 1 to 5 of 5
  1. #1 SC problem :S
    Jan 2009
    NC
    I have a 98 GP GTP and here recently a off and on whinnin sound is comin from the SC at idle to 2500 rpm anyone have a idea which bearings would cause this. there is no performance loss noticable. the car has 120k miles. the sound usually last for about 15 to 20 mins .
  2. #2 Re: SC problem :S
    Nov 2008
    Searcy,Arkansas
    Are you getting 2 different whines? If so it could be your power steering fluid is low or u pump is going out. Its kinda by ur SC and mine done that and would only whine around 15-30mph. Sounded like I had 2 SC lol.
  3. #3 Re: SC problem :S
    GXP Level Member ryangtp89's Avatar
    Maine
    Change the sc oil and see what happens
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  4. #4 Re: SC problem :S
    TDCRacing
    Guest
    Quote Originally Posted by TurboNoodle View Post
    If it's the s/c the snout bearings more than likley. There are 2.
  5. #5 Re: SC problem :S
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    there are so many things moving in that area it is hard to pinpoint sometimes. If you have never changed any of your tension pullies you should look there first. Your alternator could be going, could be your power steering(check fluid level), check the water pump to see if you have any coolant coming out the weep hole(bearing could be going bad), check oil level in the supercharger(should be just to the bottom of the threads) or you could change the supercharger oil. Check or change when the engine is cold. Hopefully your snout bearings aren't going bad.
  1. HUD problem
    By the1euge in forum General Tech Discussion
    Last Post: 08-31-2009, 12:23 PM
  2. How do i fix this problem?
    By thenervemann in forum General Tech Discussion
    Last Post: 11-01-2008, 01:49 PM
  3. Help Problem Please Look!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2008, 12:22 AM
  4. 97 gp one problem after another
    By vermsta in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2008, 08:44 PM
  5. Another HUD problem
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 03-10-2008, 05:51 PM
