Thread: installing pistons in the l67
Results 1 to 11 of 11
  1. #1 installing pistons in the l67
    May 2008
    McHenry IL
    I was told to put the id numbers on the connecting rod facing which way in the cylinder or there was some sort of way they had to go in? Yes guys i marked them but the markings all rubbed off.... =[ i forgot information would be helpful thank you.
  2. #2 Re: installing pistons in the l67
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    i did the same thing Lol.im sure sum 1 in here knows.
  3. #3 Re: installing pistons in the l67
    markings go towards the front of the motor which is the front cover side (not the flexplate side).
  4. #4 Re: installing pistons in the l67
    May 2008
    McHenry IL
    thanks bio
  5. #5 Re: installing pistons in the l67
    May 2008
    McHenry IL
    wait bio theres marks on both sides of the connecting rod?? what do you mean exactly? thanks man
  6. #6 Re: installing pistons in the l67
    pretty sure brian (reptile) said the casting numbers go towards the front of the engine.
  7. #7 Re: installing pistons in the l67
    May 2008
    McHenry IL
    Yeah i think he did say that but theres numbers on both sides of the rod?
  8. #8 Re: installing pistons in the l67
    Bastard Reptile's Avatar
    Kansas City, MO
    I don't ever remember any specifics on the rods for the L67, the L32's are specific on which side goes toward the front.....but the pistons are the ones that are important. The ID numbers go toward the timing chain end of the engine...meaning that on one side all of the numbers will be right side up, and the other side they will be upside down.
    Also, remember that those rod bolts are TTY, so you WILL need to have a new set of bolts, and a torque angle meter. If not, you will spin a bearing because your torque settings are wrong.
  9. #9 Re: installing pistons in the l67
    May 2008
    McHenry IL
    yeah we know about the tty stuff thanks reptile but reptile theres id numbers on both sides on my rods on the l67??????
  10. #10 Re: installing pistons in the l67
    May 2008
    McHenry IL
    help bump..
  11. #11 Re: installing pistons in the l67
    Wichita, KS
    The pistons matter as said, because there is a offset pin, so the direction matters, as said.
    The rods for the L67 I do not believe matter, as far as direction goes as well.
    L32 rods yes it matters, cylinders 1,3,5, the dots on the rods face the front (timing chain end) of the engine, and 2,4,6 they dots face the rear of the engine (flex plate end)
    I have only installed L32 rods with ARP bolts in any build I have ever done.
    ~F~
  1. Are my pistons screwed?
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 01-14-2010, 04:41 PM
  2. l67 SUMMIT SELLS ARE PISTONS!
    By GTPJOE90 in forum Shops and Community Heroes
    Last Post: 08-16-2009, 03:06 AM
