Thread: S/C Belt for I/C setup?
Results 1 to 6 of 6
  1. #1 S/C Belt for I/C setup?
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Which supercharger belt do i need to get for my car that will have a full size intercooler on it? It'd be great if i can get some part numbers.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: S/C Belt for I/C setup?
    Charles City, IA
    SMGPFC Two Nipple General
  3. #3 Re: S/C Belt for I/C setup?
    Moore, Oklahoma
    Depends.... Whats the height of the core? Do you have an oversized tensioner? What pulley will you run? Its a very open ended question.
    They easiest thing too do IMO, once you get the car together, drive to you're local autoparts store, try out 60"+ belts about .5" from each other and get the one that fits the tightest. I had to do this because my setup is a bit more complicated. I'm running a 2" tall IC, PC belt wrap Kit, Oversized tensioner pulley, and a 2.9". IIRC, i'm running a 66.5" belt.......
    Shawn W. Larsen
  4. #4 Re: S/C Belt for I/C setup?
    Banned - Busted For Scamming
    Feb 2009
    Have someone max the tensioner out and wrap a string around your setup and then measure the string. Then go to the parts store and ask for the closest belt equivalent or slightly longer.
  5. #5 Re: S/C Belt for I/C setup?
    Moore, Oklahoma
    I tried the string trick before, I think its much easier just driving up there and trying them out so you can get the absolute tightest fit
    My belt is as tight as a virgin on prom night...
    Shawn W. Larsen
  6. #6 Re: S/C Belt for I/C setup?
    ill end up having to do the string trick. I live 8 miles away from the nearest auto parts store so i can necesarily just drive my car there for test fitting belts. It should basically be 2.25 inches more than the belt im running since thats how tall the intercooler is. Using stock belt with all sock pulleys besides 3.4 Supercharger pulley.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
  3. New GTP badging setup
    By DesQ27 in forum Visual/Body Modifications
    Last Post: 10-14-2008, 07:03 PM
  4. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
  5. Setup Opinions
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2008, 12:41 AM
