Quote Originally Posted by Liquifire View Post
most of the code readers give you a code number that you cross reference and that tells you a description in plain english....did you get a DP with a cat in it or not and did you have the second o2 sensor reconnected with the new DP or did you have the code eliminated with the new PCM or what? but it idles normal?
I guess I'll spring for a scan tool then. Is there one that people would recommend?
I got the dp w/cat. I believe the o2 sensor was reconnected but I'll check when i get home just to be certain. Now that I'm thinking about it I'll have to check what I told Will (@ Overkill) about the o2 sensor and the PCM.
Yeah it idles normal.
