Thread: aeroforce gauge
Results 1 to 12 of 12
  1. #1 aeroforce gauge
    got it hooked up and everything but in order to turn it on i have to unplug it and plug it back in everytime? any ideas why?
  2. #2 Re: aeroforce gauge
    Ohio
    Cause thats the way it works. in order for it to come on with the key u have to do the wiring. It tells u how in the directions I think u just run the red to a switched 12v idr right off ill go out an look at mine in a minute for ya .
    00 GTP demodded and forsale
  3. #3 Re: aeroforce gauge
    Ohio
    yep red goes to switched 12v an thats it. the green and red u do not hook to anything. O also in order for wiring it like that to work u have to pull the the small red jumper out of the back of the gauge
  4. #4 Re: aeroforce gauge
    Barksdale AFB, LA
    Quote Originally Posted by speedemongtp View Post
    Red is for a switched source, and you do have to remove the jumper on the back of the gauge (if I remember correctly). The other two are for the analogue inputs.
    Glad you got the gauge. Let me know if I can help anymore.
    2009 Subaru Impreza WRX STI
  5. #5 Re: aeroforce gauge
    Ohio
    Ha writing error thanks for catching that sabre it should have said green and white do not go to anything.
  6. #6 Re: aeroforce gauge
    alright its ready to go now! totally skimmed over that in the directions....whoopsy! thanks guys!
    BTW thanks for the gauge sabre!
  7. #7 Re: aeroforce gauge
    Ohio
    anytime thats what were all here for
  8. #8 Re: aeroforce gauge
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    what exactly did yinz connect the red wire to?
  9. #9 Re: aeroforce gauge
    Wausau, WI
    a switched 12v power source
  10. #10 Re: aeroforce gauge
    I did this...the add-a-curcuit...works like a charm!
  11. #11 Re: aeroforce gauge
    Ohio
    ^ what he said. i power all my gauges off one of those.
  12. #12 Re: aeroforce gauge
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I like those things they work good
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. Aeroforce Scan Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2013, 01:39 AM
  2. Aeroforce gauge...
    By duane9586 in forum General Tech Discussion
    Last Post: 07-01-2008, 01:32 PM
