Quote Originally Posted by flrgen View Post
Ok, So i have gone ahead and made a few upgrades and now my car stalls and is undriveable. I have installed a plog, 3"dp, autolite 104s and a 180*thermostat.
Why would it stall? could there be a problem with the DP or the plog or is it more likely because i have the colder spark plugs? I also just got my Overkill PCM today, will that help the problem or is there a bigger issue at work? Thanks for your help.
Do you have something to scan your car with? If not then you need to take it somewhere to see if its throwing any codes. Could be lots of things and we would just be guessing. Your next mod should be an Aeroforce guage or something to scan your car. The pcm wont help your issue and the DP, plog and plugs are not causing this problem.
