Thread: When will my transmission blow
Results 1 to 9 of 9
  1. #1 When will my transmission blow
    GT Level Member Xorbex's Avatar
    Canada
    I know this is a hard question to answer since each car is different. I want to know around what HP mark or what set of mods is most likely going to result in a blown tranny.
    I have a 05 Comp G and will be putting a 3.4 on it with rockers and supporting mods, When am i getting into the danger zone and in the need for a new tranny?
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: When will my transmission blow
    When you put on slicks or beat the crap out of it all the time...except about 20-40K out of it IMO.
  3. #3 Re: When will my transmission blow
    there is no answer to this question. it depends how you treat it.
  4. #4 Re: When will my transmission blow
    SE Level Member The Chad's Avatar
    Harrisburg, PA
    Homer with glasses is right. Do the maintenance, use GM filters, Dexron VI, a good shift kit, and it may hold up to a good 300hp... as long as you don't beat the poop out of it like a moron! Use the new power wisely, understand how the tranny works, and don't treat it like a slave! Some guys mod beyond 300 with stock tranny's without much problem (but some guys don't mod at all and have failure early on).
  5. #5 Re: When will my transmission blow
    here are what i do to make my transmission last:
    1) no WOT in first gear
    2) no double downshifts (3-1, 4-2)
    3) no burnouts or hard throttle through corners
    3) make sure the fluid is always at the right level
    im a horrible maintanance person when it comes to transmissions. i never change my fluid or filter and my GT transmission (non-HD) lasted 135k miles full of fury. they take some beatings, but you have to treat them nicely.
  6. #6 Re: When will my transmission blow
    Canada
    Yah I understand about all the care and maintenance, but under perfect cicumstances I was just wondering how much power they can take. I am eventually going to get a racing tranny but dont want to blow a stock one before I get it. I want to invest in mods first to make her fast.
  7. #7 Re: When will my transmission blow
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    its a toss up man. i beat the snot out of my trans (stock just fwi) for 75,xxx miles. then i put on SLP headers & 3.5 pulley & she went mabey a couple weeks before craping out.
    Going back to stock *GRANT built trans BLOWN w/17k*
  8. #8 Re: When will my transmission blow
    You really should be fine with the setup you detailed.
    I am pushing 300whp, have 160K on the stock trans, and it is still holding strong. I do change the fluid and filter annually though.
  9. #9 Re: When will my transmission blow
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    pull out the differential and check and see if the large pin holding the planetary gears is getting loose. these rocket out like chryslers and blow holes in tranny cases. if u see ANY movement replace the diff
  1. supercharger blow off valve?
    By 2story in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 06:24 PM
  2. Whats Wrong Did I Blow It Up ?
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 06:10 PM
  3. HVAC doesnt blow air any speed
    By GTX in forum General Tech Discussion
    Last Post: 01-01-2009, 01:11 AM
  4. blown 2 motors need help before i blow the 3rd
    By talonpower2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 05:23 AM
  5. Honda Blow up-a-thon
    By UR LOSN in forum Off Topic Discussion
    Last Post: 02-24-2008, 10:32 PM
