Thread: Start of mods
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
  1. #41 Re: Start of mods
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    Getting there. The other "nice" and "not so nice" thing about taking the car in for the downpipe install was that they did a full vehicle inspection. Here are some of the things that I need to fix:
    R.F. wheel bearing is shot
    Front sway bar is broken (a while back, another web site tried to diagnose my "clunk" sounds over bumps, and this seems like the issue)
    Front brakes are needing replaced (I knew this already, but now I know about how much life is in them until it needs done).
    Belts are cracked (plan on replacing when I drop the pulley size anyway).
    They also said that my fuel filter was "needing attention", but I have no idea where that even is or how hard it is to replace (haven't searched yet).
    My air filter is dirty, but as soon as TDC gets me my black coupler (hint hint), I can get my new FWI intake on.
    So it looks like my list of parts is getting longer. I will be getting a set of GMPP sway bars, a new wheel bearing, new front brakes, possibly a new fuel filter. I was also wanting to get some G2 caliper paint since I will have the vehicle up for new brakes and other work.
    Add to that list the PLOG that was originally next on my list, and it is getting pricey, but most of those really NEED to be done.
    My trans. fluid is listed as "redish brown - black tent".... Not sure what the "tent" is...
    Power steering fluid is "brown" and so is the brake fluid.
    They also noted, as best as I can tell from their writing, under the pre-printed items of "22. Engine Oil Leaks and 23.Transmission Oil Leaks" that they "need attention" and used the words "Degrees Dye" or something like that which I can't read.
    Lots to do.
  2. #42 Re: Start of mods
    Wausau, WI
    Quote Originally Posted by nickbuol View Post
    Pretty sure they meant tint not tent.........
  3. #43 Re: Start of mods
    Prolly means you need to drop the pan and get a new filter and put a little bit of new tranny fluid in it...NOT FLUSH IT...just pan drop.
  4. #44 Re: Start of mods
    Apr 2008
    Marion, Iowa
    Yeah, it was on my maintenance list of things to do. Just not sure when I will get the time. I start a new job on the 17th, but it is 2 hours from "home" so there are a LOT of things that I need to do around the house before then, plus I need to finish the mod/repair list that I already have in the works. Maybe I'll have to see what tools it will take to do it, pack them up with me, and just plan on doing it some evening after work while I am at a relative's house 2 hours away.
  5. #45 Re: Start of mods
    Jack, Jack stands, drain bucket, 3-4 quarts of new Dexron VI tranny fluid...a big new towel(used to wipe out the pan and area the pan bolts to), new GM Trans. Filter...and a 10mm socket w/ ratchet...I think thats it. Oh, and some patience.
  1. mods for the gxp
    By miller in forum 5.3L V8 (LS4)
    Last Post: 01-13-2010, 01:34 AM
  2. New mods
    By Js97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2008, 04:52 PM
  3. Mods to Help MPG
    By anks106 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2008, 08:14 PM
  4. Gt mods?
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2008, 07:16 AM
  5. GT mods
    Last Post: 03-06-2008, 12:21 PM
