Thread: 3.8L SC Random stalls, faulty intermittent start!
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #1 Re: 3.8L SC Random stalls, faulty intermittent start!
    SE Level Member bumpingtp's Avatar
    Brighton, MI
    Engine will run and suddenly die without warning
    Engine will not or not easily restart
    Tachometer may drop to zero but the car will continue to run
    it has all of the symptoms of a CPS failure, except i DONT lose spark, and the tcs light doesnt come on. and my CPS was replaced not too long ago.
  2. #2 Re: 3.8L SC Random stalls, faulty intermittent start!
    Feb 2008
    Quote Originally Posted by bumpingtp View Post
    it happens all the time. it started as just studdering randomly once in a while, and sometimes the tach would die randomly too. it progressively got worse and worse. at first it would die, then start right back up, the i'd have to wait 5 minutes to restart it, now i have to wait 10+ to restart it. it does it all the time, temperature doesnt matter. it's done it when it 90*, it also does it when it's well below freezing.
    That sounds like the some of the problems I'm starting to have. Mine started with just a random stutter at low RPM's and progressed to stopping all together at low RPM, especially when I'm decelerating or making my way through a parking lot. It'll start back up instantly (for now).
  3. #3 Re: 3.8L SC Random stalls, faulty intermittent start!
    Brighton, MI
    today, i took the time to do almost exactly as agentbluescreen advised, minus the fan wiring. i took used 6 3/4" x 3/4" pieces of micarta, approx. 3/16" thick, to hopefully reduce heat transfer. i also put some foil tape on one edge of each piece, as advised above. i'll update in a week or so and let everyone know how it's working.
  4. #4 Re: 3.8L SC Random stalls, faulty intermittent start!
    I had to space my ICM to fit my belt after installing my intercooler.
    Just used some bolts and nuts.
  5. #5 Re: 3.8L SC Random stalls, faulty intermittent start!
    Brighton, MI
    didnt work. car stalled yesterday. it's kinda weird, when i leave it in gear i can put the gas pedal to the floor and it slowly bogs and dies, but if i put it in neutral i can rev it freely, but it backfires when i let off the gas. im open for new suggestions!
  6. #6 Re: 3.8L SC Random stalls, faulty intermittent start!
    this issue was mostly found in the dead of summer. not winter.
  7. #7 Re: 3.8L SC Random stalls, faulty intermittent start!
    Brighton, MI
    it does it year round. CPS was replaced, along with the harness
  8. #8 Re: 3.8L SC Random stalls, faulty intermittent start!
    illinois
    My 98 GTP is doing this and it also hiccups time to time. I went to autozone they said MAF. I cleaned the MAF and it is completely fine. I took my car to NTB they said MAP sensor so I repleaced the map sensor put in all new plugs and wires and still have the same issue. My car runs fine the first couple of minutes until the engine wars up and then it seems to run like crap. I checked and all of the recall stuff was taked car of back in 09 when I had them originally addressed. I also had the coils tested and stuff before the tune up. I also installed anew PCV valve. Any suggestions on what I am dealing with and how to fix them? Some mechanic said I probably need to get my injectors cleaned out but that makes no sense if the car runs fine when its cold and crappy when hot
  9. #9 Re: 3.8L SC Random stalls, faulty intermittent start!
    SE Level Member agentbluescreen's Avatar
    Detroit/Windsor
    This is a photo of a fouled CPS center-magnet. Note all the "hair" of metal filings on the middle magnet. This both weakens and 'spreads out or shifts" the center polar point.
    This is what it should/will look like if "new" or after it's just cleaned off with a damp rag, the magnet is very weak, you don't even have to remove it to do this.
    I apologize for the blurry pic, but you get the idea... it can't/won't work properly with all those metal filings stuck on the magnet. On the inner 6X side of the sensor, wind from the rotating vane causes the spark to advance (on the highway) but as this wind diminishes (lower RPM) the magnetic "hairs" (along magnetic field lines) straighten up and the filings across the top and sides rejoin with one-another, weakening the overall magnetic field. This ironically results in almost the same ignition problems as pitted points and a bad distributor cap do, now easier to remedy but much harder to get at .
  10. #10 Re: 3.8L SC Random stalls, faulty intermittent start!
    Detroit/Windsor
    If you are short of cash (removing the 7" main crankshaft pulley to service or replace the $35 CPS sensor at a shop will cost you at least 2 hours -$75 labor) one other possible way to clean the filings off the rather weak magnet of the CPS sensor is to squirt high pressure water into the crack between the pulley and the engine block from the top/front (forward) edge of the back of the crankshaft pulley-engine block crack downwards, hopefully flushing the filings out.
    The CPS and wiring is completely encapsulated and fairly waterproof, but the plastic foreign object protector may make this method of water-flushing to clean the magnet off (without pulley removal) not work at all or not work too well. If the problem is really severe this emergency quick fix may reduce it or buy you a bit of time, in any event the water down there behind the pulley in the crankshaft bearing area will drain out quickly and can't do much harm to anything down there. (psst - the crankshaft pulley is like a centrifuge, it will quickly suck-blow the water out like a spin dry cycle)
    This method of flush cleaning the Hall Magnet works on the wheel hubs for the ABS/TCS sensor magnets. The stationary ABS/TCS sensor is on the lower part of (each front) axle block. People usually just replace the whole axle block/bearing/hub and sensor as a single unit, but it is also only "foreign object protected" in the hub/block gap allowing ferrous dust to get in there and foul the sensor's magnet, which cannot be accessed, cleaned, removed or replaced.
    Again the sensor and magnet are completely plastic encapsulated, (though the backs of GM harness connectors just have rubber grommets and aren't too water resistant) so water in this area (not on wire-entry backs of connectors) is not much of an issue. YMMV
    Always do your utmost to avoid getting water into the back wire-entry points of GM (and all) automotive electrical connectors, at that location they are merely rubber grommet "splash resistant" not "waterproof".
  11. #11 Re: 3.8L SC Random stalls, faulty intermittent start!
    Detroit/Windsor
    Another note about the left front (passenger) ABS/TCS sensor wiring on GTP's with the chronic warped front plastic manifold cover oil leak (they tried to just get away with putting a fatter gasket ROFL) is that this oil crud leaks down onto the top of the passenger side axle/control arm/rail. This is also where a second ABS/TCS sensor extension-cable wire from the passenger front sensor connection to the main engine harness lays.
    Over time oil accumulation there will cause corrosive salt and brake rotor grindings to adhere to the connector and wires and thus, with moisture, to eventually get into the back of both of the connector's (rather leaky and loose) rubber-grommet splash-seals. This will cause leakage in the insulation values and may make the passenger-wheel sensor signal drop off, the easiest solution is to clean it with high pressure water. It's just down below the passenger side radiator plumbing connections 10" towards the center, laying on the rail.
    Again get your dealer to fix the fire hazard SC recall repair again and/or get under the car and clean the extension connector-backs off (use brake cleaner) and then seal them good with some silicone to prevent oil/salt/water penetration.
  12. #12 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    agentbluescreen,
    Thanks so much for all of your posts. They're very helpful to all of us - and our mechanics! - who are having the same woes.
    This is such a simple question I'm a bit afraid to ask it, but here goes: since the cars having these elusive problems typically have many K miles on them, and since you say gunk and corrosion are major culprits, would having the engine compartment steam-cleaned solve part of the problem, apart from the high-heat issue? I'm just thinking that these cars ran fabulously for sooo long, even with all of the high heat, so I'm wondering what has developed, and, since so many of us have replaced parts 'til our wallets are blue in the face, it doesn't seem old, worn-out parts are the whole problem....
    Also, it's been 1.5 weeks since your last post - - how's it going with your car now - - is it still stall- and non-start-free? If so, you seem to be the only one who has conquered this gnarly beast!
  13. #13 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    P.S. My 98 Grand Prix 3.8 V6 SE, with 205K miles, does the stall thing (on and off the highway) & the not-start thing (for varying amounts of wait-time), for the last four months. It of course seems to be, like agentbluescreen's, after short stops (like going to lunch) and when the weather is warmer - and during the later evening after a warm day.
    The dash lights I have on are: ABS, Non-Trac and intermittently (like on one week, off the next) the Service Engine Light (That light has been doing that for literally years, with the car running beautifully).
    We've replaced: CPS, wiring harness, fuel filter, fuel relay, fuel pump, ICM, plugs and the 2009 Recall wire "channel" or whatever it's called.
    We've checked: plug wires/boots, battery connectors, MAF and EGR.
    The codes have repeatedly been checked and cleared, and currently there's only CPS "A" and EGR. The first is new, the second was examined and OK.
    That's my story an' I'm stickin' to it.
  14. #14 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    Oh - and tach needle dropping to zero & staying there 'til next start - and this still happens, even though we just replaced the ICM - and it usually happens soon before either a stall or a non-(re)start.
    'Interesting thing: The car usually does better when the gas tank is full... maybe something to do with the gas staying cooler and so keeping other things relatively cooler?
  15. #15 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    Man, I keep thinking of more things to say!...
    I have also smelled the strong smell of gas after a stall with non-(re)start. We haven't replaced the fuel pressure regulator yet, but we've already spent over $2K without success, and replacing parts doesn't seem to be doing it, and others have replaced that part & the problem remained....
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  3. 97 GT intermittent start
    By airhead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 06:43 AM
  4. Car Stalls PLEASE HELP!!!
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 05:26 PM
  5. Intermittent idiling around 2k & other Stuff
    By FlatlinerD in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2008, 10:33 PM
