Thread: 3.8L SC Random stalls, faulty intermittent start!
Results 1 to 20 of 37
  1. #1 Re: 3.8L SC Random stalls, faulty intermittent start!
    SE Level Member agentbluescreen's Avatar
    Detroit/Windsor
    Another note about the left front (passenger) ABS/TCS sensor wiring on GTP's with the chronic warped front plastic manifold cover oil leak (they tried to just get away with putting a fatter gasket ROFL) is that this oil crud leaks down onto the top of the passenger side axle/control arm/rail. This is also where a second ABS/TCS sensor extension-cable wire from the passenger front sensor connection to the main engine harness lays.
    Over time oil accumulation there will cause corrosive salt and brake rotor grindings to adhere to the connector and wires and thus, with moisture, to eventually get into the back of both of the connector's (rather leaky and loose) rubber-grommet splash-seals. This will cause leakage in the insulation values and may make the passenger-wheel sensor signal drop off, the easiest solution is to clean it with high pressure water. It's just down below the passenger side radiator plumbing connections 10" towards the center, laying on the rail.
    Again get your dealer to fix the fire hazard SC recall repair again and/or get under the car and clean the extension connector-backs off (use brake cleaner) and then seal them good with some silicone to prevent oil/salt/water penetration.
  2. #2 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    agentbluescreen,
    Thanks so much for all of your posts. They're very helpful to all of us - and our mechanics! - who are having the same woes.
    This is such a simple question I'm a bit afraid to ask it, but here goes: since the cars having these elusive problems typically have many K miles on them, and since you say gunk and corrosion are major culprits, would having the engine compartment steam-cleaned solve part of the problem, apart from the high-heat issue? I'm just thinking that these cars ran fabulously for sooo long, even with all of the high heat, so I'm wondering what has developed, and, since so many of us have replaced parts 'til our wallets are blue in the face, it doesn't seem old, worn-out parts are the whole problem....
    Also, it's been 1.5 weeks since your last post - - how's it going with your car now - - is it still stall- and non-start-free? If so, you seem to be the only one who has conquered this gnarly beast!
  3. #3 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    P.S. My 98 Grand Prix 3.8 V6 SE, with 205K miles, does the stall thing (on and off the highway) & the not-start thing (for varying amounts of wait-time), for the last four months. It of course seems to be, like agentbluescreen's, after short stops (like going to lunch) and when the weather is warmer - and during the later evening after a warm day.
    The dash lights I have on are: ABS, Non-Trac and intermittently (like on one week, off the next) the Service Engine Light (That light has been doing that for literally years, with the car running beautifully).
    We've replaced: CPS, wiring harness, fuel filter, fuel relay, fuel pump, ICM, plugs and the 2009 Recall wire "channel" or whatever it's called.
    We've checked: plug wires/boots, battery connectors, MAF and EGR.
    The codes have repeatedly been checked and cleared, and currently there's only CPS "A" and EGR. The first is new, the second was examined and OK.
    That's my story an' I'm stickin' to it.
  4. #4 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    Oh - and tach needle dropping to zero & staying there 'til next start - and this still happens, even though we just replaced the ICM - and it usually happens soon before either a stall or a non-(re)start.
    'Interesting thing: The car usually does better when the gas tank is full... maybe something to do with the gas staying cooler and so keeping other things relatively cooler?
  5. #5 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    Man, I keep thinking of more things to say!...
    I have also smelled the strong smell of gas after a stall with non-(re)start. We haven't replaced the fuel pressure regulator yet, but we've already spent over $2K without success, and replacing parts doesn't seem to be doing it, and others have replaced that part & the problem remained....
  6. #6 Re: 3.8L SC Random stalls, faulty intermittent start!
    May 2011
    SoCal
    OK, another thing:
    agentbluescreen also mentioned vacuum leaks, and I know there's a crack at the back of my manifold cover (I don't get how this works, but my mechanic replaced the part of it -?- that fixed a crack at the front, that was letting major exhaust into the cab; there's still some coming in now when I'm sitting in my driveway idling, but when I get moving it blows away behind the car).
    Could a small crack in the manifold cover be the stalling/not-starting culprit?
  1. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  2. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  3. 97 GT intermittent start
    By airhead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 06:43 AM
  4. Car Stalls PLEASE HELP!!!
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 05:26 PM
  5. Intermittent idiling around 2k & other Stuff
    By FlatlinerD in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2008, 10:33 PM
