Thread: coolant leak help???!!!
Results 1 to 14 of 14
  1. #1 coolant leak help???!!!
    SE Level Member silverbullet10's Avatar
    minnesota
    I noticed a leak coming from the hose that leads to the water pump. its on the left side of the motor right below the supercharger nose. anyone had this problem or suggestions? or how to fix or what else could possibly be wrong?
  2. #2 Re: coolant leak help???!!!
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Is it underneath the water pump or above it. If its underneath, could be the weep hole on the water pump itself telling you that its about to go out. If its above, it could be a cracked coolant elbow.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  3. #3 Re: coolant leak help???!!!
    WOW?????!!!!!! I"d really like to help...but do you drive???????!!!!!!!!!!!!
    Ps, I love the exclaimtions/question marks.
    If you have a 3.8, then it's the coolant elbows. There's a few write ups. Basics are pull alt, pull alt bracket (don't forget the bolt in the back taht you can't see) and presto $4 (Dorman 47065) fixes you up.
  4. #4 Re: coolant leak help???!!!
    Nov 2009
    Indiana
    wow. Is it really that simple? I have the exact same leak on mine and located it with no issue, but just been adding coolant daily since I couldnt find out anything about that elbow. Thanks for the dorman number. Will go get it tomorrow and fix a month long problem!
  5. #5 Re: coolant leak help???!!!
    Yeah...it is overall easy. First time, it's gonna seem like a legit repair. After that.. it's pull alternator, 3 more bolts, clean the old elbows out. Lube o-rings, slide them in..wiggle as you tighten and put alt back on.
  6. #6 Re: coolant leak help???!!!
    SE Level Member julian2875's Avatar
    Feb 2009
    ny
    no the DORMAN ARE CRAP PARTS GO WITH GM PARTS FOR THIS BELIEVE ME u dont wanna change it every 6 months......................
    heres the parts
    Elbow to lower intake manifold (LIM) - GM Part # 24503423
    Elbow to water pump - GM Part # 12565082
  7. #7 Re: coolant leak help???!!!
    Quote Originally Posted by julian2875 View Post
    heres the parts
    Take a close look at the Dorman/Napa brands next to the OEM's. They were identical when I looked at them. Likely produced in the same factory. If you have problems with them leaking or failing... review the installation techniques. I've found there are ways to install them that make them fail and ways to install that give near 100% success.
  8. #8 Re: coolant leak help???!!!
    You must have been doing something wrong...the Dorman elbows are the only ones anyone ever uses around here.
  9. #9 Re: coolant leak help???!!!
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    put mine im almost exactly 6 months ago. no leaks. if u dont force them and lube them theyll b fine. ud be suprised how much stuff is made in the same factory.
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  10. #10 Re: coolant leak help???!!!
    Nov 2009
    Indiana
    So I bought the elbow today, it comes with both elbows in the package. Now it just sucks since I just moved back to alaska i dont have my tools, need to see what i need to get the job done. I think its a 15mm on the tensioner to loosen belt, then 13mm on alt ? anybody know off hand? If so Id appreciate it. if not no biggie, just figure no harm in asking, its a 98gtp 3.8 s/c
  11. #11 Re: coolant leak help???!!!
    13mm and 15mm and you can do the whole job.
  12. #12 Re: coolant leak help???!!!
    Feb 2009
    ny
    hey whatever u guys say but the dorman parts look very thin.
    thx
  13. #13 Re: coolant leak help???!!!
    Nov 2009
    Indiana
    so ur all right, not bad repair at all. was a bit stressed at first when had all bolts off and alt bracket still wouldnt come off, was just the o ring on the other coolant elbow. thanks!
  14. #14 Re: coolant leak help???!!!
    Mercer, Pa
    The manifold hole gets pitted. I had to use rtv with new elbows.
  1. Coolant leak help!!!
    By Sl33p3rGt in forum General Tech Discussion
    Last Post: 12-21-2010, 03:58 PM
  2. Coolant Leak
    By rippemblue2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2010, 11:30 AM
  3. Coolant leak fix.
    By Rcrevolution in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2010, 11:57 PM
  4. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
  5. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
