Thread: Keyless remote entry
Results 1 to 17 of 17
Threaded View
  1. #3 Re: Keyless remote entry
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Negative.
    Important note - you MUST program all of your keyless remotes when you do this - NOT JUST THE NEW ONE. You are in essence - changing the channel/remote address of the vehicle and remote, and your old remotes will not work.
    1) Get in car and close all doors.
    2) In the fuse panel - remove the "MALL PGM" fuse - do not lose this!
    3) Insert key and turn ignition to ACC position - you should hear the interior chime once
    4) Turn key to "off" and quickly back to ACC.
    5) Open and close the driver's door. You should hear 1 chime - this will indicate that the system has entered diagnostic mode.
    6) Press and hold both the lock and unlock buttons on the transmitter (key fob) - for approximately 15 seconds. You should hear a chime after 7 seconds, DO NOT RELEASE THE BUTTONS - continue to hold for a second chime.
    7) Repeat step 6 for each transmitter. (maximum of 4 can be programmed for each vehicle)
    8) If you're finished programming, turn ignition off.
    9) Replace “MALL PGM” fuse.
    10) Open Door(s).
    11) Test transmitters.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  1. Remote Keyless Entry
    By quijibo in forum Audio, Security & Visual Electronics
    Last Post: 05-21-2009, 11:58 AM
  2. Keyless Entry?
    By mossman925 in forum General Tech Discussion
    Last Post: 04-21-2009, 08:28 PM
  3. Help with remote start/keyless entry
    By Red97GPGT in forum Audio, Security & Visual Electronics
    Last Post: 03-13-2009, 10:50 PM
  4. Did all 04 GP come standard with remote keyless entry
    By serenityacres in forum 04+ Specifics
    Last Post: 02-20-2009, 04:53 PM
  5. My keyless entry broke
    By biggmman in forum General Tech Discussion
    Last Post: 10-18-2008, 12:11 AM
