Thread: High idle?
Results 1 to 15 of 15
  1. #1 High idle?
    Donating Users JESSEGOTTA GP GT's Avatar
    NC
    So I've been here before, but with GT's and never a GTP. I finally bught one, and I have a few questions I can't find answers to... first one is my idle... When I start the car up it will be about 1000 rpm's then it will work it's way up to about 1500 rpm's then very slowly work it's way down to 1200, and stay there. I've spayed brake cleaner all over and can't find a vac leak. (no CEL either) I also noticed that it doesn't want to "pull" its self when it's in drive, you have to give it some gas for it to start moving, but the tranny seems ok? Any ideas? Also, has anyone ever changed a power steering pump on these L67's? Mine is leaking quite a bit. Thanks in advance for your help! I'll post pics of the car soon....
    New project: 2000 Red GTP.
  2. #2 Re: High idle?
    Unplug the MAF sensor and see if it settles, and do the same with the throttle postion sensor.
    See what the car does.
  3. #3 Re: High idle?
    NC
    I'll go try it now!
  4. #4 Re: High idle?
    NC
    No luck, gonna upload a video
  5. #5 Re: High idle?
    NC
    Can't get the video to upload, but looking around on youtube I guess it's the MAF? No CEL on or anything. When I unplugged it, it didn't make a difference.
  6. #6 Re: High idle?
    No worries on the vid. Your idle is controlled by the IAC or idle air control valve. This is right above the TPS. It's possible your TB/IAC area/seat is dirty. I'd suggest starting with an easy TB cleaning. Holler if it's still doing it after that.
  7. #7 Re: High idle?
    NC
    Cleaned the whole TB, and lowered my rpm's to about 900. But now I'm noticing what I thought was a bad supercharger coupler is my transmission? It sounds like it's buzzing and doesn't hold its self in drive very well? But it drives fine and changes gears as smooth as butter...
  8. #8 Re: High idle?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I've done the power steering pump on the L67. It was kind of a pita. Just don't forget the o ring from the pump to the resaviore. I forgot about it and once I started the engine, turned the wheel a few times and most of the fluid poured out almost instantly. Had to do it all over again haha. Now this pump is making some noise -.-
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  9. #9 Re: High idle?
    NC
    Here is a video of the high idle/ "buzzing" sound from the transmission. It might be hard to hear, but my speakers pick it up good. It's not the intake making the buzzing sound. Any ideas?
    tranny noise - YouTube
  10. #10 Re: High idle?
    If your speakers pick it up..it's electrical.
  11. #11 Re: High idle?
    NC
    Nope. It's probly hard to hear in the video because of the freaking intake sucking all the air out of the ozone. It changes sounds when I put the tranny all the way into 1st and work my way up to park, but 2nd and park/neutral seem to be the loudest.
  12. #12 Re: High idle?
    I went on what you posted in text not the vid. You said your speakers pick it up well. That means your car audio system is putting it out.
    Microphones record audio...not speakers.
  13. #13 Re: High idle?
    GT Level Member Toms04compg's Avatar
    Michigan
    Yeah what bill said... Ever have a system or deck in your car with a bad ground it makes a straight high audio tone to match with your rpms lol. The video doesnt play
  14. #14 Re: High idle?
    Tom.. I read into what he said in his latest post. He thinks speakers pick up sound in teh video. Not getting feedback from the electrical system.
    That's why I tossed out the educational tip about microphone vs speaker.
  15. #15 Re: High idle?
    NC
    I ment my computer speakers pick up the sounds in the video well haha sorry should've specified.
    See if this link works:
    http://www.youtube.com/watch?v=YG9df...ature=youtu.be
  1. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  2. High idle at times
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2010, 07:48 AM
  3. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  4. 98 GTP high idle problem
    By mikegtp in forum General Tech Discussion
    Last Post: 10-09-2009, 02:05 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
