Well after weeks of putting it off I finally tackled the LIM. I went ahead and did the valve cover gaskets as well since the back one was leaking. The job overall was not bad if you follow the video posted on this site you should be able to do it. I ran into a couple of issue one BECAREFUL when taking the vacuum lines off as I broke all the rubber pieces so I will be going to Pontiac tomorrow to hopefully by them. The next issue is I can't figure out where this damn plug gets plugged into. It's 3 prongs and has purple around the connector, any thoughts?
