Thread: Hard to Explain
Results 1 to 18 of 18
  1. #1 Hard to Explain
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Well here goes. The car sounds rough and loud in reverse when Aplying gas. It sounds like it is coming from the passanger side. This started when I put the headers and the new Axles in the car. Any Idea I know it sounds weird and it is hard to explain
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Hard to Explain
    Exhaust could be rubbing when the motor flexes forward. That would be my first guess.
  3. #3 Re: Hard to Explain
    Wausau, WI
    look for any rub marks on the exhaust....
  4. #4 Re: Hard to Explain
    Charles City, IA
    Probaly the clamp the holds the bottom of the cross over to the rear header. I think mine is rubbing too.
    SMGPFC Two Nipple General
  5. #5 Re: Hard to Explain
    Naugatuck CT
    Ok so it should not be something to worry about too much I will check that. Thanks
  6. #6 Re: Hard to Explain
    May 2008
    McHenry IL
    G.l its probably something easy =p
  7. #7 Re: Hard to Explain
    Charles City, IA
    I am planning on checking mine tonight. I am pretty sure it was something to do with the headers. Since we both have the same issue right after I installed mine.
  8. #8 Re: Hard to Explain
    Banned - Busted For Scamming
    Feb 2009
    Yea your headers are more than likely rubbing the firewall. You need cradle spacers or longer dogbones
  9. #9 Re: Hard to Explain
    Wausau, WI
    or a torch..........
  10. #10 Re: Hard to Explain
    Feb 2009
    Quote Originally Posted by Liquifire View Post
    Explain.
  11. #11 Re: Hard to Explain
    Charles City, IA
    ^ probably making a funny saying we should cut the firewall.
  12. #12 Re: Hard to Explain
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by jacobmh27 View Post
    If you're car is making any unnatural noise - and you don't know where it's coming from OR what's causing it - be concerned.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  13. #13 Re: Hard to Explain
    Eh?? Or better headers. IF this is the problem - something is amiss with those headers. Badly.
    -Swash
  14. #14 Re: Hard to Explain
    Naugatuck CT
    it only happens in reverse ad it is just louder it is weird. I will look into the firewall when Iget home from LA next weekend
  15. #15 Re: Hard to Explain
    Wausau, WI
    you got it.........
  16. #16 Re: Hard to Explain
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    define loud? is it like exhaust loud or mechanical loud. i only ask because you just did the axle too and you didnt specify why you changed it. just thought id try a different avenue. i figure these guys r correct but if its not that you at least have something else to think about
  17. #17 Re: Hard to Explain
    Naugatuck CT
    that is what I thought mabey the Axel was not in all the way but it is already checked that. I was getting a vibration on aceleration so that is why I changed them the boots were torn and they just about fell apart when I took them out
  18. #18 Re: Hard to Explain
    Wausau, WI
    so did you figure it out yet?
  1. How Hard To Hit
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 12:00 AM
  2. someone explain what part is broken..maybe..
    By Bio248 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-17-2009, 10:22 PM
  3. How hard to fix???
    By duane9586 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2009, 02:56 PM
  4. Can someone explain to me how a 2 Stage Nitrous kit works?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-28-2008, 10:36 PM
