Thread: Supercharger Noise
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Supercharger Noise
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    well I just finished replacing the coupler and changing the oil. The noise I had is alot quieter but I can still hear it faintly. Could it possibly be the needle case bearings? how hard are they to replace?
    Call me Brad
    '06 GT: Just a few mods here and there.
  2. #22 Re: Supercharger Noise
    SE Level Member juanathandavid's Avatar
    oakdale
    Hi Guys,
    I just picked up a 99 GTP last week and I keep reading about this supercharger oil.
    I'm a fluid-changing junky so I want to make sure all my fluids in this vehicle are fresh - dude I looked and I can't see where this SC oil goes or how to change it. Is there a link to a write-up or how-to?
    Thanks!
  3. #23 Re: Supercharger Noise
    Jan 2009
    Long Island
    Quote Originally Posted by juanathandavid View Post
    Hi Guys,
    Thanks!
    Pontiac Grand Prix GTP Eaton M90 Supercharger Oil Change Picture Illustrated Guide
    Good Luck!
  4. #24 Re: Supercharger Noise
    oakdale
    wow that was fast. Thanks!!!
  5. #25 Re: Supercharger Noise
    Michigan
    Quote Originally Posted by Clar2478 View Post
    I am wondering the same. Mine is rolling 90K and I know I need to change the coupler soon.
    08 GXP all stock
  6. #26 Re: Supercharger Noise
    Dec 2008
    Springfield Illinois 62703
    Blower has to come off
    Did the oil that you pulled out come out clear or black?
    did it seem that you didnt get a lot of oil out of it compared to the 2 new bottles you put in?
    If the needle beariings are bad you will get rotor slap and maybe a rattle
    more likely a bearing in the snout (there are 2)
    Talke the pulley and grasp it, see if there is any movement up and down on the shaft, that would indecate the front snout beraring.
    Also take a stethescope and listen on the snout, there will be a little noise up by the pullry with it running, but it shouldnt be growling real loud
  7. #27 Re: Supercharger Noise
    Nov 2008
    Idaho
    The rattle is coming more from the throttle body side of the S/C, I've got case bearings on the way and should be here this week. I'll post back up what I find out.
    Call me Brad
  8. #28 Re: Supercharger Noise
    Wausau, WI
    good luck...........keep us posted
  1. SuperCharger Noise
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2012, 11:47 PM
  2. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  3. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
  4. supercharger noise at idle
    By slippyskippy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 08:14 PM
  5. Supercharger noise and questions
    By DMohr87 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:11 PM
