Thread: Supercharger Noise
Results 1 to 20 of 28
  1. #1 Supercharger Noise
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    Popped the hood today just to look a few things over while it was running and immediately noticed a noise coming from the supercharger. It sounds like the rotors were grinding. Not like a TERRIBLE grinding, but it definiktely sounded like there was more friction between them than there should have been.
    Any suggestions on what needs to be done? I also manually ?opened? the boost bypass valve just by pushing the metal rod into the housing and the grinding would stop until i released it.
    Call me Brad
    '06 GT: Just a few mods here and there.
  2. #2 Re: Supercharger Noise
    Sure it is Supercharger? Use a 15mm and take the belt off to be sure. Start it without the blower and if the sound is gone than it was coming from it. Maybe your coupler is bad...then again you have a GenV and they are known for getting noisey and clacky over time...something normal.
  3. #3 Re: Supercharger Noise
    Nov 2008
    Idaho
    So if it's known for it, should I be worried? Do I need to replace the S/C oil or anything else, or just let it do it's thing?
    Call me Brad
  4. #4 Re: Supercharger Noise
    SE Level Member Orbital431's Avatar
    Albuquerque, NM
    Quote Originally Posted by Clar2478 View Post
    it wouldn't hurt if it was changed. good precaution to take just to cover ur a**.
  5. #5 Re: Supercharger Noise
    Barksdale AFB, LA
    Based off your description it sounds like when the blower I bought had bad needle bearings. Without hearing it myself I can't tell you for sure.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Supercharger Noise
    Might need a new coupler and a oil change
  7. #7 Re: Supercharger Noise
    Nov 2008
    Idaho
    I also noticed that my boost has decreased by about 1.5psi
    Call me Brad
  8. #8 Re: Supercharger Noise
    Albuquerque, NM
    bad gasket? losing boost pressure somewhere
  9. #9 Re: Supercharger Noise
    Nov 2008
    Idaho
    it happened the same time the noise started.
    Call me Brad
  10. #10 Re: Supercharger Noise
    Nov 2008
    Idaho
    Well after driving my car around for a bit this morning it seems like my boost levels are lower when the motor isn't as warm. For the first 20 or so minutes, the most boost I would see was around 7lbs. I stopped at a friends house for 5 minutes, left the car running and left. I got back on it 2 more times (both were all the way through 1st and 2nd) and peaked my boost around 9.8lbs. I'm going to order a coupler and s/c oil tomorrow to see if it fixes the noise im getting, But I'm still curious if the difference in the boost levels is being caused by this as well or if its normal, or something else.
    Call me Brad
  11. #11 Re: Supercharger Noise
    Dec 2008
    Springfield Illinois 62703
    X2
    How many miles on the SC?
    IS it running a stock pully?
    Take off the belt and see if there is any play in the rotation. Rock it back and forth if it clicks and gives, then the coupler is mostly likely the problem.
    We just changed my sone 98 with 90000 miles today. If you need directions on doing the swap let me kno.
    Oh'And everyone will tell you that it takes 2 bottles of GM Sc oil 8 Oz
    Well on all of the ones we have done (4 now ) it takes just a tad over 2 bottles
  12. #12 Re: Supercharger Noise
    Nov 2008
    Idaho
    it's got just over 60,000 on it, im running a 3.4" pulley. I'll pull the belt tomorrow after work to see what I get.
    Thanks for the info on the S/C oil.
    Call me Brad
  13. #13 Re: Supercharger Noise
    Not to beat on a dead horse here, but you have a GenV'ed car with a 3.4" supercharger pulley...you got mods?! Those things have issues handling a 3.6" knock free...sure it is the blower making those noises now that I think about it...take the belt off to see if the noise stops...if it doesn't, I'd be worried elsewhere...but that is just me.
  14. #14 Re: Supercharger Noise
    Nov 2008
    Idaho
    yeah I've got mods, I've also got an aeromotive scan gauge. I've got very minimal knock retard and it's at the VERY end of each gear.
    Call me Brad
  15. #15 Re: Supercharger Noise
    Dec 2008
    Brad
    How opften if ever have you changed the Sc oil
    If not to you check it in occasion to see of the fluid is at the threads?
    60000 is not a lot of miles,Sc should be good
    bluegtp91 may be right on with removing the Sc belt and running the engine.
    See if the noise is something else
  16. #16 Re: Supercharger Noise
    Nov 2008
    Idaho
    I just finished pulling my SC belt and the noise stopped. Put it back on and the noise came right back. So am I safe to assume its the coupler? I just got one ordered so it should be here by the end of the week along with SC oil. I also tried spinning the SC by hand, when I rocked it back and forth rapidly I could hear a slight tick like the holes on the coupler might be slightly worn, not sure though.
    This will be the first time I've changed it so I'll update this thread when I get it done. On another note, anyone have any idea on my boost situation I posted above, or if it would be related since it started the same time as the noise did?
    Call me Brad
  17. #17 Re: Supercharger Noise
    Charles City, IA
    I don't think the boost problem is related to the coupler. From what you have described it sounds like the coupler. I am not sure on your boost problem tho.
    SMGPFC Two Nipple General
  18. #18 Re: Supercharger Noise
    Nov 2008
    Idaho
    who knows, I could just be paranoid about this whole coupler deal. we'll see once I get it swapped.
    Call me Brad
  19. #19 Re: Supercharger Noise
    Just make sure you go buy a turkey baster and have a container to put the old oil in you don't care about b/c you'll never want to put anything BUT S/C oil in it again
    It's easy...don't worry...just take your time...I did it without pulling the alternator, but I would advise you taking it off lol Makes life a lot easier
  20. #20 Re: Supercharger Noise
    Nov 2008
    Idaho
    I've already got a syringe and hose to remove the oil and plenty of ziploc disposable containers i can use to hold the oil. thanks for the info on removing the alternator
    Call me Brad
  1. SuperCharger Noise
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2012, 11:47 PM
  2. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  3. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
  4. supercharger noise at idle
    By slippyskippy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 08:14 PM
  5. Supercharger noise and questions
    By DMohr87 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:11 PM
