Thread: i need help on changing supercharger oil
Results 1 to 20 of 25
  1. #1 i need help on changing supercharger oil
    Donating Users
    Apr 2009
    Laredo, Texas, United States
    i was wondering how to change or where i can take it to get my supercharger oil changed
  2. #2 Re: i need help on changing supercharger oil
    SE Level Member scottmmckinney's Avatar
    Apr 2009
    Chesterton, IN
    You need a Torx/Allen head bit and a rachet. The plug is on the snout, simply loosen that and suck the old out. A turkey bastor with a long rubber hose works best. Then purchase 1-2 bottles of GM Supercharger oil and squirt the new back in. Simple as that!
  3. #3 Re: i need help on changing supercharger oil
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    One of my favourite ways to ge the oil out is to get an old windex bottle and put the hose end in the snout and spray the oil out into the neck of the bottle. once you are finnished screw the spray bottle neck back into the bottle and store for the next swap.
    Engineering the impossible.
  4. #4 Re: i need help on changing supercharger oil
    Oklahoma
    I know not its not common to have, but I use my oil sampling pump to pull out the oil supercharger oil.
    A used oil bottle fits perfectly to it so I just stick the tube down in the nose and suck out the old fluid into the used oil bottle and then pour in the new.
  5. #5 Re: i need help on changing supercharger oil
    Nov 2008
    Searcy,Arkansas
  6. #6 Re: i need help on changing supercharger oil
    Donating Users
    Apr 2009
    alright thx u guys for the info
  7. #7 Re: i need help on changing supercharger oil
    May 2008
    McHenry IL
    just did mine 2 seconds ago its sooo simple dude ha i used a old windex squirter "yes i cleaned it first" ha
  8. #8 Re: i need help on changing supercharger oil
    Ohio
    ^ they all said it exactly. its a very easy job. WARNING! It stinks!
    00 GTP demodded and forsale
  9. #9 Re: i need help on changing supercharger oil
    May 2008
    McHenry IL
    yes yes it did! i seriously almost blew chunks ha
  10. #10 Re: i need help on changing supercharger oil
    Jersey
    i liked the smell
    16' wrx sti- stock
  11. #11 Re: i need help on changing supercharger oil
    Nov 2008
    Searcy,Arkansas
    Quote Originally Posted by 99prixgt View Post
    i liked the smell
    Smells like powering steering fluid to me....LOL
  12. #12 Re: i need help on changing supercharger oil
    Aug 2008
    Long Island, New York
    Quote Originally Posted by Jess3103 View Post
    all i know is nothing can smell worse than gear oil... that stuffs just nasty
  13. #13 Re: i need help on changing supercharger oil
    May 2008
    McHenry IL
    well ur special =] jk bro ha
  14. #14 Re: i need help on changing supercharger oil
    Apr 2009
    Pennsylvainia
    I am new to the whole supercharger and how often are you supposed to change the supercharger oil?
  15. #15 Re: i need help on changing supercharger oil
    Nov 2008
    Searcy,Arkansas
    Quote Originally Posted by stuckwish05 View Post
    I really don't think it "brakes" down as fast as basic oil. I changed my when it was around the 35k mark. It needed it BIG TIME!
  16. #16 Re: i need help on changing supercharger oil
    SE Level Member 07CrimsonGT's Avatar
    Apr 2009
    Oxford, Ohio
    I took a gander at mine the other day, and at 26k it looks brand new. No bad smells either, but then I am a car guy so what smells like crap to one, might be a walk in the roses to another.
  17. #17 Re: i need help on changing supercharger oil
    Ohio
    Im thinkin i read somewhere that you should change it about every 50,000
  18. #18 Re: i need help on changing supercharger oil
    Apr 2009
    Oxford, Ohio
    Merlin:
    Thanks a bunch for the windex suggestion. My turkey baster was an el cheapo model, and kept letting what little fluid it would suck up run out before I could get the snout out of the hole.
    For reference, I was cutting my teeth by changing the oil in the charger on my good friends 99 Park Avenue Ultra. From what I could tell, the fluid was oem at 70k.
    Good Lord, that fluid looked like 20 year old brake fluid, and smelled like boiled buzzard pus from the 15th Century!!!!!!!!
    I got about 7 ounces out of it, and refilled it to the bottom of the filler hole threads.
    Anyway, What model of charger is on the 99 engines, and what model is on our newer 04 and up 3.8's
    Don
  19. #19 Re: i need help on changing supercharger oil
    Ohio
    gen 3 on the 97-03. gen V on the 04 and up
  20. #20 Re: i need help on changing supercharger oil
    God I wish S/C oil smelled like P.S. fluid...sure would make my life a lot easier
  1. changing oil pan gasket
    By ratnick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-29-2009, 08:52 PM
  2. changing over to a new oil need opinons please
    Last Post: 06-01-2009, 12:46 AM
  3. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
  4. Thinking of changing oil
    By GTP4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2008, 04:00 PM
  5. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
