Thread: How can i run my car on E85?
Results 1 to 14 of 14
  1. #1 How can i run my car on E85?
    SE Level Member basshead42's Avatar
    Toledo, OH
    I hear of guys running e85 in their grand prixs. Are there and mods that need to be done to use this gas? What are the benefits? And does it have more octane than 94?
    2000 GTX--3.4 pulley, MSD wires, NGK Iridium plugs 2 ranges colder, 180* Tstat, U-Bend delete, DHP 1.0 PCM, Ram-Air, headers are next!
  2. #2 Re: How can i run my car on E85?
    Barksdale AFB, LA
    Larger injectors and a tune.
    2009 Subaru Impreza WRX STI
  3. #3 Re: How can i run my car on E85?
    Quote Originally Posted by Sabrewings View Post
    you are correct sir. along with changeing your fuel filter a couple times because the e85 will clean your tank out.
    i might be selling a set of 65# injectors coming up. i need a new transmission...
    benefits: 105 octane all the time, cleans out the motor
    cons: you have to use more fuel, but the fuel is a little cheaper
  4. #4 Re: How can i run my car on E85?
    Aug 2008
    Long Island, New York
    i would consider doing this, too bad e-85 isnt available anywhere near me, i love the thought of running 105 octane all the time
  5. #5 Re: How can i run my car on E85?
    SE Level Member 07CrimsonGT's Avatar
    Apr 2009
    Oxford, Ohio
    BH:
    The E85 is quite a different animal, and is very corrosive to the entire fuel system. Vehicles that are OEM equipped to run on it are manufactured with parts that will withstand the volativity of the fuel.
    Putting E85 into a vehicle not made for it will most likely result in a big repair bill for you later if not sooner.
    I would research it completely so you know what you are getting into before you do this.
    Don
  6. #6 Re: How can i run my car on E85?
    Barksdale AFB, LA
    Quote Originally Posted by 07CrimsonGT View Post
    BH:
    Don
    Modern vehicles are ready for E85. It's older vehicles that were built before E10 become widely available that you should be cautious. Any vehicle that can run on E10 already has synthetic seals in the fuel system and E85 will do no harm.
  7. #7 Re: How can i run my car on E85?
    BH:
    Don
    whoever told you e85 is corrosive was smoking crack.
    read a chemistry book. ethanol (pure) is not corrosive. e85 (85% ethanol + 15% gas) is also not corrosive.
  8. #8 Re: How can i run my car on E85?
    GT Level Member massivesystem's Avatar
    Apr 2008
    I have a 2007 grand prix GT along with the mods in my sig, do still need to change injectors to run E85?
    Thanks
    2007 Pontiac Grand Prix GT Series III 3.8 Super Charged
    AL 104's Plugs, 180* T-Stat, Tuned PCM , Custom CAI is complete and installed, AeroForce Interceptor gauge, Smoothflow 3.5 pulley with 0* KR, SSAC SS Headers. 6000K HID
  9. #9 Re: How can i run my car on E85?
    Apr 2009
    Oxford, Ohio
    Gentlemen:
    After reading your postings, I did a bit of research, and confirmed that e85 is somewhat corrosive as is gasoline.
    The point to my posting was to encourage BS42 to make sure he has all the facts before he fills up his GP with E85.
    I do know that E85 operable vehicles that are OEM do have different components in their fuel systems to make the vehicle work properly with E85. Common sense says they would not do it if it was not necessary.
    While I do not claim to be a know it all, I have seen a lot of bad advice given out on internet forums over the years, and would not want to be the victim of it.
    You can run a diesel engine on kerosene if you need to, but that does not mean doing it would be right or good for the car long term.
    E-85 ethanol is used in engines modified to accept higher concentrations of ethanol. Such flexible-fuel engines are designed to run on any mixture of gasoline or ethanol with up to 85% ethanol by volume. The primary differences from non-FFVs is the elimination of bare magnesium, aluminum, and rubber parts in the fuel system, the use of fuel pumps capable of operating with electrically conductive (ethanol) instead of non-conducting dielectric (gasoline) fuel, specially-coated wear-resistant engine parts, fuel injection control systems having a wider range of pulse widths (for injecting approximately 60% more fuel), the selection of stainless steel fuel lines (sometimes lined with plastic), the selection of stainless steel fuel tanks in place of terne fuel tanks, and, in some cases, the use of acid-neutralizing motor oil. For vehicles with fuel-tank mounted fuel pumps, additional differences to prevent arcing, as well as flame arrestors positioned in the tank's fill pipe, are also sometimes used.
    Don
  10. #10 Re: How can i run my car on E85?
    Quote Originally Posted by massivesystem View Post
    Thanks
    yes. yes you do. the stock injectors wont run enough fuel to keep up on e85. youll need to use about 30% more fuel.
    the reason why ethanol is worse off than gas is if your car sits a lot youll have problems with water collecting in comparison to gas. that is what will eat away your fuel system not the fuel itself. if your car sits a lot i would not suggest running e85, but if you start it up every so often or drive it a few times a week at least then youre money. e85 will not eat away anything any more than regular gas would so i wouldnt be scared at all to run it.
    ive done my fair share of research on it as well since i am planning on running it at some point.
  11. #11 Re: How can i run my car on E85?
    Apr 2008
    What Injectors would I need to run? And where is the best place to purchas them.
  12. #12 Re: How can i run my car on E85?
    im not sure which ones you need for your car. i would look at ZZP for what you need and then try to find them somewhere else cheaper.
  13. #13 Re: How can i run my car on E85?
    Apr 2008
    thanks bro
  14. #14 Re: How can i run my car on E85?
    Barksdale AFB, LA
    You'll need PCM tuning or an AFC to use different size injectors.
car, e85, run
