-20* washer fluid is only 30/70 mix.
if i drove my car everyday i would probably fill up the tank once a month at the most. cant say where you can find meth, but try local chemical dealers.
do you use just regular alcohol in your tank? is there much of a difference between using alcohol and meth? how big is your tank? and once you have your car tuned for alcohol injections, you MUST always have it flowing right?
