Thread: methanol injection questions
Results 1 to 18 of 18
  1. #1 Re: methanol injection questions
    -20* washer fluid is only 30/70 mix.
    if i drove my car everyday i would probably fill up the tank once a month at the most. cant say where you can find meth, but try local chemical dealers.
  2. #2 Re: methanol injection questions
    milford
    do you use just regular alcohol in your tank? is there much of a difference between using alcohol and meth? how big is your tank? and once you have your car tuned for alcohol injections, you MUST always have it flowing right?
    even if you walk on water, some will say that you cant swim...
  3. #3 Re: methanol injection questions
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I thought I read that the Wal-Mart stuff is pretty much 50/50? I remember that adding a bottle of HEET to the bottle of -20°F washer fluid would be almost exactly 50/50?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  1. Ask your water methanol injection questions here.
    By DevilsOwn in forum General Tech Discussion
    Last Post: 07-15-2009, 09:54 PM
  2. Methanol/water injection
    By gtp59 in forum General Tech Discussion
    Last Post: 04-01-2009, 09:59 PM
  3. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
