here an 02 regal
Document ID# 781286
2002 Buick Regal
Powertrain Control Module Connector End Views
Table 1: Powertrain Control Module (PCM) Connector C1
Table 2: Powertrain Control Module (PCM) Connector C2
Connector Part Information
12191110
80-Way F Micro-Pack 100W Series, Sealed (BLU)
Pin
Wire Color
Circuit No.
Function
BLK
2762
Low Reference
2-3
Not Used
LT GRN
1222
1-2 Shift Solenoid Valve Control
DK BLU
473
High Speed Cooling Fan Relay Control
6
DK GRN
335
Low Speed Cooling Fan Relay Control
7
BLK
630
Camshaft Position Signal
8
PPL/WHT
430
Low Resolution Engine Speed Signal
9
LT BLU/BLK
647
Medium Resolution Engine Speed Signal
10
GRY
2704
5 Volt Reference
11
Not Used
12
BLK
2761
Low Reference
13
ORN/BLK
469
Low Reference
14-15
Not Used
16
BLK/WHT
451
Ground
17
BLK
2760
Low Reference
18
Not Used
19
PPL
1500
Ignition 0 Voltage
20
ORN
540
Battery Positive Voltage
Not Used
22
PNK
1224
Transmission Fluid Pressure Switch Signal A
23-27
Not Used
28
TAN/WHT
1669
HO2S Low Signal
29
TAN
413
HO2S Low Signal
30
PPL
420
TCC Brake Switch/Cruise Control Release Signal
31
BLK
2753
Low Reference
32
GRY
435
EGR Solenoid Low Control
33
DK BLU
496
KS (1) Signal
34
LT BLU
1876
Knock Sensor 2 Signal
35-37
Not Used
38
LT GRN/WHT
1749
IAC Coil B High Control
39-42
Not Used
43
YEL/BLK
846
Fuel Injector 6 Control
44
YEL/BLK
1223
2-3 Shift Solenoid Valve Control
PNK/BLK
429
AIR Solenoid Control (L36)
Not Used (L67)
46
LT BLU/BLK
844
Fuel Injector 4 Control
47
BLK/WHT
845
Fuel Injector 5 Control
48
RED/BLK
453
Low Reference
49-52
Not Used
TAN/BLK
424
IC Timing Signal
54
WHT
423
IC Timing Control
55
DK GRN/WHT
817
Vehicle Speed Signal
56
BLK/WHT
451
Ground
57
BLK/WHT
451
Ground
58
DK GRN
1049
PCM Class 2 Serial Data
59
Not Used
60
BLK/WHT
451
Ground
61
BLK
2752
Low Reference
62
DK BLU/WHT
1231
AT ISS Low Signal
RED/BLK
1230
AT ISS High Signal
64
YEL
400
Signal High-Front
65
PPL
401
Signal Low-Front
66-67
Not Used
68
YEL
772
Transmission Range Switch Signal B
69
YEL
492
MAF Sensor Signal
70
Not Used
71
ORN/BLK
463
Requested Torque Signal (67)
71
Not Used (L36)
72
DK GRN
83
Cruise Control Inhibit Signal
73
LT GRN/BLK
1745
Fuel Injector 2 Control
74-75
Not Used
76
DK GRN/WHT
428
EVAP Canister Purge Solenoid Control
77-78
Not Used
79
BLK
1744
Fuel Injector 1 Control
80
BLK
2751
Low Reference
12191110
80-Way F Micro-Pack 100W Series, Sealed (CLR)
Pin
Wire Color
Circuit No.
Function
Not Used
WHT
1310
EVAP Canister Vent Solenoid Control
DK GRN/WHT
465
Fuel Pump Relay Control
WHT
257
EGR Solenoid High Control
BRN/WHT
419
MIL Control
6
Not Used
7
LT BLU/WHT
1747
IAC Coil A High Control
8
Not Used
9
TAN/BLK
464
Delivered Torque Signal (L67)
9
Not Used (L36)
10
PPL
412
HO2S High Signal
11
PPL/WHT
1668
HO2S High Signal
12-15
Not Used
16
WHT
776
Transmission Range Switch Signal P
17
RED
1226
Transmission Fluid Pressure Switch Signal C
18
BLK/WHT
771
Transmission Range Switch Signal A
19
TAN/BLK
231
Oil Pressure Switch Signal
20 -21
Not Used
22
DK GRN/WHT
762
A/C Request Signal
23
PPL
806
Crank Voltage
24
PNK
439
Ignition 1 Voltage
25
LT GRN
432
MAP Sensor Signal
26
YEL
410
ECT Sensor Signal
27
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
28
BRN
1456
EGR Valve Position Signal
29
Not Used
30
GRY/BLK
2702
5 Volt Reference
31-32
Not Used
33
GRY
2701
5 Volt Reference
34
GRY
474
5 Volt Reference
35
BLK
452
Low Reference
36-38
Not Used
39
DK GRN/WHT
459
A/C Compressor Clutch Relay Control
40-41
Not Used
42
PNK/BLK
1746
Fuel Injector 3 Control
43
Not Used
44
LT BLU/BLK
1748
IAC Coil A Low Control
RED/BLK
1228
PC Solenoid Valve High Control - Sol. A
46
LT BLU/WHT
1229
PC Solenoid Valve Low Control - Sol. A
47-48
Not Used
49
LT GRN/BLK
444
IAC Coil B Low Control
50
TAN
472
IAT Sensor Signal
51-54
Not Used
55
DK GRN
890
Fuel Tank Pressure Sensor Signal
56
GRY
773
Transmission Range Switch Signal C
57
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
58
BRN
1174
Oil Level Switch Signal
59
WHT
85
Cruise Control Engaged Signal
60
Not Used
61
RED
225
Generator Turn On Signal
62
Not Used
YEL
657
TCC Release Switch Signal
64-65
Not Used
66
DK BLU
417
TP Sensor Signal
67
Not Used
68
YEL/BLK
1227
TFT Sensor Signal
69
PPL
1589
Fuel Level Sensor Signal - Primary
70-74
Not Used
75
BRN
436
AIR Pump Relay Control (L36)
75
Not Used (L67)
76
YEL/BLK
625
Starter Enable Relay Control
77
GRY
1724
Boost Control Solenoid Control (l67)
77
Not Used (L36)
78
BRN
418
TCC PWM Solenoid Valve Control
79-80
Not Used
Document ID# 781286
2002 Buick Regal
