here is the pinout reference for the 97. ill get the 02 in a second...
Document ID# 106977
1997 Pontiac Grand Prix
Engine Controls Connector End Views
PCM 80-Way Blue Connector C1 Details
Connector Part Information
Blue PCM Connector C1
Body - 12160549
TPA - 12160569
Terminals - 12084913
Shield - 12160921
Pin
Wire Color
Circuit No.
Function
Component Connector Cavity
DTC(s) Affected
Possible Symptoms From a Faulty Circuit
Lt Blu/Blk
647
18X Reference
ICM C
P0336
Intermittent fault will cause engine miss/cut-out, Inoperative Tachometer
Blk
630
Camshaft Position PCM Input
ICM F
P0341
6
Yel
400
VSS High
VSS B
P0502
Speedometer inoperative, late/harsh shifting, chuggle
Cruise Control Disabled
7
Red/ Blk
1230
Automatic Transmission Input (Shaft) Speed Sensor (AT ISS Sensor) (VIN 1 Only )
Transmission Connector S
P0716/P0717
Refer to 4T65-E Automatic Transaxle Diagnosis
8
Dk Grn/Wht
465
Fuel Pump Relay
Fuel Pump Relay 85/A5
None
Stall/no start
9
Lt Blu/Wht
1747
IAC A High
IAC C
P0506/P0507
High or low idle, stalling
10
Lt Grn/Blk
444
IAC B Low
IAC B
P0506/P0507
11
Lt Blu/Blk
1748
IAC A Low
IAC D
P0506/P0507
12
Lt Grn/Wht
1749
IAC B High
IAC A
P0506/P0507
13
Dk Grn/Wht
817
4K/Mi Speed
Go to Vehicle Speed Sensor, Cruise
None
Speedometer inoperative, Cruise Control inoperative
14
Orn/Blk
463
Traction Control Desired Torque (With Traction Control System RPO NW9 Only )
EBTCM Connector C3 Cavity B
P1571
Traction Control disabled, Traction OFF Lamp illuminated
15
Tan
800
Serial Data
Go to Power, Ground, MIL, DLC
16
Gry
416
5 Volt Reference A
TP Sensor C, MAP Sensor C, and EGR Valve D
P1635, P0101, P0122, P1107, P1122, P1406
Late shifting, incorrect/rough idle, stalling, surging
17
Gry
474
5 Volt Reference B
A/C Refrigerant Pressure Sensor B, Fuel Tank Pressure Sensor C
P1639, P0530
A/C compressor inoperative
18
19
Pnk
439
Ignition Feed
P0560
No start
20
Orn
540
Battery Feed
P0560
No start
Blk/Wht
451
PCM Ground
None
Intermittent symptoms
22
Brn
418
TCC PWM Solenoid Driver
Transaxle Connector C (VIN K), T (VIN 1)
P1860
Refer to 4T60-E(Vin K)
4T65-E(Vin1)
23
Gry
1724
Boost Control Solenoid (ODM A Output 5) (VIN 1 Only )
Boost Control Solenoid B
P1645, P1257
Rough Idle, Reduced Performance
24
25
Brn/Wht
419
MIL Driver
P1641
No MIL, MIL ON Steady
26
27
Lt Grn
497
Fuel Pump Speed Control (VIN 1 Only )
Fuel Pump Speed Control Relay 85/A3
P1643
Noisy fuel pump (Pump operates in high speed only ), Lean condition during high load conditions (Pump operates in normal speed only )
28
Tan/Blk
422
TCC Enable Solenoid Driver (VIN K Only )
Transaxle Connector D
P1860
Refer to 4T60-E AutomaticTransaxle Diagnosis
29
Gry
435
EGR Control
EGR Valve A
P1406, P1635
Incorrect/rough idle, lack of power, chuggle
30
Dk Grn/Wht
428
EVAP Canister Purge Driver
EVAP Canister Purge Solenoid B
P1655, P0441, P1441
Rough idle
31
Dk Blu
473
Fan 2 Driver (High Speed)
Go to Coolant Fans schematic
P1652
High Speed Fans inoperative, High Speed Secondary Fan ON all the time, incorrect idle, possible overheating condition
32
Dk Grn
335
Fan 1 Driver (Low Speed)
P1651
Low Speed Fans inoperative, Low Speed Fans ON all the time, incorrect idle, possible overheating condition
33
34
35
Dk Grn/Wht
459
A/C Compressor Clutch Relay Driver
A/C Compressor Relay F8/86
P1654
Incorrect/rough idle A/C compressor inoperative
36
37
38
39
40
41
42
43
44
Ppl/wht
430
3X Reference
ICM D
P1374
Stalls, sets DTC on restart
Red/Blk
453
Reference Low
ICM L
Intermittent Symptoms
46
Dk Blu/Wht
1231
Automatic Transmission Input (Shaft) Speed Sensor (A/T ISS Sensor) (VIN 1 Only )
Transmission Connector V
P0716/P0717
47
Ppl
401
VSS Low
VSS / TOSS A
P0503F
Speedometer inoperative, late/harsh shifting, chuggle, Cruise Control Disabled
48
49
50
51
52
Tan/Blk
424
Bypass
ICM B
P1361
Wht
423
Ignition Control (IC)
ICM A
P1350, P1361
54
Yel
492
MAF Signal
MAF Sensor A
P0101, P0102, P0103
Reduced performance
55
Dk Blu
229
Theft Deterrent
Theft Deterrent A3
1626/1629
Stall/No Start
56
Blk
452
Sensor Ground
ECT Sensor A, TP Sensor A, MAP Sensor A, IAT Sensor A, A/C Refrigerant Pressure Sensor A, EGR Valve B, Transmission Connector G (VIN K) M (VIN 1)
P0108, P0118, P0123, P0530, P0713, P1106, P1115, P1121, P1406
Incorrect/rough idle, lack of power late/harsh shifting, chuggle, A/C compressor inoperative, Fuel gauge inoperative
57
58
59
Dk Grn
1809
Class 2 Data
DLC 2
None
No scan tool data
60
Blk/Wht
451
PCM Ground
None
61
62
Dk Grn/Wht
762
A/C Request
A/C Controller Connector C2 Cavity B
P0530
A/C Compressor inoperative
65
66
Ppl
1986
EVAP Canister Purge Vacuum Switch B
P1441
67
Ppl
420
TCC Brake Switch
TCC Brake Switch D
Refer to 4T60-E (VIN K) / 4T65-E (VIN 1) AutomaticTransaxle Diagnosis
68
Pnk
339
EGR Ignition Positive Voltage
Go to Engine Data Sensors-A/C Refrigerant Pressure, TP, MAP, ECT, IAT
P0401, P1406, P0133, P0135, P0141
Fuse blown, EGR Pintle Position error on scan tool varies excessively
69
Blk/Wht
771
Transaxle Range Signal A
Trans Range / Park Neutral Position Switch D
P0705, P0706
Idle flare when clutch is disengaged
70
Brn
1174
Engine Oil Level Switch
Oil Level Switch A
Low Oil Lamp ON for 7 minute after startup
71
72
776
Wht
Transaxle Range Signal P
Trans Range / Park Neutral Position Switch A
P0705, P0706
PCM defaults to D4 Gear select Position
73
74
75
Wht
85
Cruise Status
SMCC II Cruise Control Module J
P1554
76
77
78
79
80
PCM 80-Way Clear Connector C2 Details
Clear PCM Connector C2
Body - 12160549
TPA - 1216056A
Shield - 12160921
Pin
Wire Color
Circuit No.
Function
DTC(s) Affected
7
Brn/Wht
1173
Oil Oil level Lamp Control
Go to Indicator Lamps
DTC 1672
No Oil Lamp,Lamp On Steady
8
Gry
803
Change Oil Soon Lamp Control
9
Wht
121
Tachometer Indicator Control
10
Dk Grn
35
Hot Lamp
DTC 1673
11
Lt Grn
1222
Shift Solenoid A Driver
Transmission Connector A
P0753
Refer to 4T60-E (VIN K) / 4T65-E (VIN 1) Automatic Transaxle Diagnosis
12
Lt Grn
432
Manifold Absolute Pressure Sensor
MAP Sensor B
P0107, P0108, P1106, P1107
Default Manifold Absolute Pressure and BARO
13
Dk Grn
83
Cruise Inhibit Driver
SMCC II Cruise Control Module H
P1662
14
15
16
Brn
25
Generator Lamp Control
DTC 1663
17
Yel/Blk
1223
Shift Solenoid B Driver
Transmission Connector B
P0758
18
19
20
Lt Blu/Wht
1229
Pressure Control Solenoid Valve low
Solenoid D
P0748
Blk/Wht
451
PCM Ground
None
22
Pnk/Blk
1746
Injector Cylinder 3
Injector Connector B
P1200, P0300
Incorrect/Rough Idle, Missing, Flashing MIL
23
Yel
772
Transaxle Range Signal B
Trans Range / Park Neutral Position Switch B
P0705, P0706
24
Lt Grn/Blk
1745
Injector Cylinder 2
Injector ConnectorB
P1200, P0300
25
Gry
773
Transaxle Range Signal C
Trans Range / Park Neutral Position Switch C
P0705, P0706
26
Blk
1744
Injector Cylinder 1
P1200, P0300
27
Pnk
1224
Trans Fluid Pressure Switch A Input
Transmission Connector N
28
Yel/Blk
846
Injector Cylinder 6
P1200, P0300
29
Dk Blu
1225
Trans Fluid Pressure Switch B Input
Transmission Connector R
30
Blk/Wht
845
Injector Cylinder 5
P1200, P0300
31
Red
1226
Trans Fluid Pressure Switch C Input
Transmission Connector P
32
Lt Blu/Blk
844
Injector Cylinder 4
P1200, P0300
33
Dk Blu
1493
Performance Shift switch Input
Sw A
34
35
Red
225
Generator Control
Generator L
P0560
Charging system inoperative, Generator lamp commanded ON
36
37
38
39
40
41
42
43
44
Ppl
412
HO2S 1 Signal
HO2S 1 B
P0131, P0132, P0133, P0134
Open loop fuel control, incorrect/rough idle
46
Tan
413
HO2S 1 Low
HO2S 1 A
P0134
47
Ppl/Wht
1668
HO2S 2 Signal
HO2S 2 B
P0137, P0138, P0140
48
Tan/Wht
1669
HO2S 2 Low
HO2S 2 A
P0140
49
50
51
Tan
472
Intake Air Temperature Sensor
IAT Sensor B
P0112, P0113, P1111, P1112
52
Yel
410
Engine Coolant Temperature Sensor
ECT Sensor B
P0117, P0118, P1114, P1115
Hard Start, Incorrect/Rough Idle, Cooling Fans Commanded On
Dk Blu
417
Throttle Position Sensor
TP Sensor B
P0122, P0123, P1121, P1122
Late/Harsh Shifting, TPS Default
54
55
56
57
58
59
60
Blk/Wht
451
PCM Ground
61
Red/Blk
1228
Pressure Control Solenoid Valve High
Transmission Connector C
P0748
62
Gry
23
Generator F Terminal
Generator F
Volts Lamp ON
Dk Blu
496
Knock Sensor Signal 1
Knock Sensor
P0327
Default Knock Retard commanded
64
Lt Blu
1876
Knock Sensor signal 2
Knock Sensor
P0327
65
Brn
1456
EGR Pintle Position
EGR Valve C
P1406
Incorrect/Rough Idle, Cuts-out/Misses, Chuggles
66
67
68
69
70
71
Yel/Blk
1227
Transaxle Fluid Temperature Sensor
Transaxle ConnectorF (VIN K), L (VIN 1)
P0712, P0713
72
73
Red/Blk
380
A/C Refrigerant Pressure Sensor C
P0530
A/C Compressor Inoperative
74
75
Yel
657
TCC Release Switch Input
Transmission Connector U
P1887
76
77
78
79
80
Document ID# 106977
