Thread: engine will start only if
Results 1 to 12 of 12
  1. #1 engine will start only if
    GXP Level Member ryangtp89's Avatar
    Maine
    Id figure id right about whats going on with my car.
    So every single time i go to start it up i must give it a little gas as soon as it starts up, if i just start it up without touching the gas peddal it goes way below ideling rpm's and dies in a few seconds. It does this every time. Im not sure wat this could be. If i tap the gas just a little bit or however much i want it will be fine and it will idel fine.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: engine will start only if
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Tiny vac leak ?
    Or maybe a TPS or sticky TB plate ?
    Lumpy Gen 3
  3. #3 Re: engine will start only if
    Maine
    Do you think its cause of my chrome oil breather ?
  4. #4 Re: engine will start only if
    Toronto, ON, Canada
    Quote Originally Posted by ryangtp89 View Post
    Put a stock one back on and see if it fixes the problem !
    Lumpy Gen 3
  5. #5 Re: engine will start only if
    Maine
    well my scanner didnt read anything soo idk
  6. #6 Re: engine will start only if
    Maine
    Ok ill do that. thanks
  7. #7 Re: engine will start only if
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    you should not have a breather unless you blocked off the pcv.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  8. #8 Re: engine will start only if
    Maine
    Yea i hear 50/50 its ok and then its not ok. But im gonna put the stock one back on when ever i find it.
  9. #9 Re: engine will start only if
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    If you have to hold the throttle open to keep it running it may be a problem with the IAC. Even with only 20K miles on my car the IAC was pretty dirty.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  10. #10 Re: engine will start only if
    Maine
    oh really ? cause i just have to like pump it once and its fine.
  11. #11 Re: engine will start only if
    St Louis MO
    Never mind. That is a weird problem you have. With the XP and extremely cold weather I have to do the same thing only I hold it slighly open for a second to get the initial air to the engine.
    2010 Camaro SS LS3
  12. #12 Re: engine will start only if
    Maine
    Yea it is probably something to do with the cold weather.
  1. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
  2. want to add shock sensor to existing car security/remote start
    By fst in forum General Tech Discussion
    Last Post: 01-11-2008, 06:55 PM
  3. car and Engine pics
    By Jason Austin in forum Visual/Body Modifications
    Last Post: 01-07-2008, 10:18 PM
  4. Car dead, wont start !!FIXED!!
    By Maybe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2008, 11:27 PM
  5. LS9 Corevette Engine, Supercharged
    Last Post: 01-03-2008, 02:28 PM
