U1000 Lost Communication With ECM/PCM "A" Code pcm might be going bad. is your power port also not working? if so check the fuse for it, the obd2 port is powered off the same fuse.
when setting up the scanner, you need to be in the car running and it hooked up, then the highlighted green items are use able.
