Thread: Scanner not reading KR?
Results 1 to 12 of 12
  1. #1 Scanner not reading KR?
    Dec 2018
    Lehigh Valley, PA
    I have an android tablet with torque pro (with the GM PIDS installed) and a BAFX OBD2 Bluetooth adapter. It reads everything properly (speed, rpm, coolant temp, etc) but KR stays at 0 no matter how hard I get on it. I have a hard time believing this car has absolutely zero knock, even at WOT through the full rpm range. I also lugged the car around in OD with the converter locked at about 45 and even up a slight grade, no KR on the scanner. Is that possible? The car in question is the 2004 Monte Carlo SS Dale jr edition. (L67 car) and running 93 octane. The only known modification is a 160 degree thermostat. No idea what plugs are in it. I haven't tried this scanner in the GTP yet, but I will as soon as the GTP is fixed.
  2. #2 Re: Scanner not reading KR?
    Dec 2018
    Lehigh Valley, PA
    Well, I finally got a KR reading of 1 degree, so it's working on the Monte Carlo. Tried it on the GTP and It won't read ANY data, and it's throwing the code U1000 (Class 2 Communication Malfunction). Any idea what that could be?
  3. #3 Re: Scanner not reading KR?
    Dec 2018
    Lehigh Valley, PA
    Anybody have any experience with the U1000 code?
  4. #4 Re: Scanner not reading KR?
    Feb 2019
    ON
    No experience with the code but I have had issues with Torque Pro reading KR. Sometimes it reads, sometimes it doesn't. You're not the only one
  5. #5 Re: Scanner not reading KR?
    U1000 Lost Communication With ECM/PCM "A" Code pcm might be going bad. is your power port also not working? if so check the fuse for it, the obd2 port is powered off the same fuse.
    when setting up the scanner, you need to be in the car running and it hooked up, then the highlighted green items are use able.
  6. #6 Re: Scanner not reading KR?
    Dec 2018
    Lehigh Valley, PA
    And I set it up on the GTP the same way I did the Monte Carlo and it reads everything on the Monte just fine.
  7. #7 Re: Scanner not reading KR?
    Dec 2018
    Lehigh Valley, PA
    power port works, just won't connect
  8. #8 Re: Scanner not reading KR?
    the obd blue tooth light up when plugged in? if so the pcm is crapping out id think.
  9. #9 Re: Scanner not reading KR?
    Dec 2018
    Lehigh Valley, PA
    Yup, crap. It does light up, and the blue tooth connects with my tablet too. It specifically says the blue tooth is not connected to the ecm. Well, I guess it's time for a new pcm.
  10. #10 Re: Scanner not reading KR?
    theres a guy on FB zeph hatten, hes in the 3800 performance and 3800 market place pageas. he's offering 50 dollar tunes. im not sure if thats with a pcm or not, but worth looking into. guy knows his 3800 tunes, helped mine out for sure.
  11. #11 Re: Scanner not reading KR?
    Dec 2018
    Lehigh Valley, PA
    I hooked my regular code scanner into the GTP on Saturday since I fixed my exhaust leak and I wanted to see if I could get the handheld scanner to read from the port. At first it didn't, but it prompted me with an option to "reinstate PIDs" to which I opted yes. A few seconds later, the scanner was working, I was able to read and erase the codes for the CEL, and see the real time data that I couldn't see with the blue tooth connector and my tablet running torque pro. Naturally I had to see if the blue tooth adapter would be able to connect now too. So I hooked it up and BAM, it all works now. I can see all the data on my tablet. That's the good news!
    The bad news is that even though I'm still 100% stock, at WOT under load, I'm seeing as much as 5.6 degrees of KR! I ALWAYS put 93 octane in it from Sunoco. No exceptions. I'm gonna put in some colder plugs and see if that helps. I even noticed a degree of KR at part throttle with vacuum still reading on the scanner. Not even in boost. ?
  12. #12 Re: Scanner not reading KR?
    i had 8 bone stock. you need flow mods. like a 3 inch downpipe or headers. rockers also help
  1. Maf g/s reading
    By Zzp98gs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2015, 06:19 PM
  2. reading kr
    By buschegt in forum General Tech Discussion
    Last Post: 06-11-2015, 09:17 AM
  3. Reading MAF in Hz?
    By 94GrandPrixSE in forum PCM Tuning
    Last Post: 03-28-2014, 04:13 PM
  4. ODB 2 Scanner.
    By Blueraven in forum General Tech Discussion
    Last Post: 11-24-2009, 10:43 AM
  5. MAP reading
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2009, 12:34 AM
