BillBoost37
it would be lumped in with something else. You'd want the wiring diagrams..if it wasn't lighting up like you said it does. So that's not the issue. Most likely the pcm being programmed with a different year from say bcm etc.. is not seeing the correct information coming back to it.
Seems that you are having other issues with the cam and p0300 that should have been removed. Personally, I'd remove the codes and smile as long as everything else is working well.
