Thread: SS intercooler and header install = engine codes
Results 1 to 3 of 3
  1. #1 SS intercooler and header install = engine codes
    Apr 2009
    alberta
    After installing my ZZ performance ss intercooler and my headers I now have the following codes that I cant seem to make go away. Suggestions?
    Codes
    P0171 system too lean Bank 1
    P0304 cylinder 4 misfire detected
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    Can anyone help me
  2. #2 Re: SS intercooler and header install = engine codes
    Charles City, IA
    Tech Tips post your shortcut ideas, things that make a job easier. Please use the How To section to post up full details on modifications/repair
    Does the intercooler have provisions to even run the egr?
    Are your headers leaking before the 02 sensor?
    SMGPFC Two Nipple General
  3. #3 Re: SS intercooler and header install = engine codes
    in a house
    Quote Originally Posted by rascal View Post
    Codes
    Can anyone help me
    You have a vacuum leak. What gaskets did you use? The ss i/c requires a Gen 5 gasket between the i/c core and lim and a Gen 3 gasket between the i/c core and s/c. Get some throttle body cleaner and start spraying while the motor is running all around the i/c core,lim and s/c. When the idle picks up u found the leak... Is it idling like crap?Hopefully you just knocked a vacumm line loose or your gonna have to tear it back apart
  1. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  2. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  3. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  4. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
  5. header install advice.
    Last Post: 01-02-2009, 02:28 PM
