Thread: Trouble codes after header install
Results 1 to 12 of 12
  1. #1 Trouble codes after header install
    I'm getting trouble codes after i fixed my burnt wiring following my header install. I'm getting a P0102 maf or vaf a circuit low input and a P1676 which my code reader says dtc not found. When i try to rev my car it cuts out for a sec then catches up. Does the same thing with the maf unhooked. I also am running catless and don't have a rear O2.
  2. #2 Re: Trouble codes after header install
    Jul 2011
    Edmonton, AB
    Maf issue forsure.. Forgot to hook up my maf after header install.. Freaked me out lol
  3. #3 Re: Trouble codes after header install
    Jul 2011
    Edmonton, AB
    P1676 has something to do with the evap system I beleive
  4. #4 Re: Trouble codes after header install
  5. #5 Re: Trouble codes after header install
    Nov 2008
    Waterloo, Iowa
    I didn't do headers but got the P1676 after having my EGR removed and doing a ported S/C and tune. Nick just tuned it out for me.
  6. #6 Re: Trouble codes after header install
    PA
    What wires were burnt and how did you fix them? Are their others?
    2001 GSE
  7. #7 Re: Trouble codes after header install
    Charles City, IA
    You still have an egr you dont have evap.
    SMGPFC Two Nipple General
  8. #8 Re: Trouble codes after header install
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by TheOtherNick View Post
    Then why did we tune out the EGR code? :P
  9. #9 Re: Trouble codes after header install
    I soldered them together. no others. It was a vacuum leak at the brake booster. My trans dipstick was pushing against it lol
  10. #10 Re: Trouble codes after header install
    and also my tb is leaking all around it so i guess i'll pull it off and reclean it
  11. #11 Re: Trouble codes after header install
    Im guessing the p1676 is from not have a post cat O2
  12. #12 Re: Trouble codes after header install
    I figured it out!!! When the wiring burnt it popped the #21 fuse under the hood. Changed the fuse and all is good I'm very happy now i can beat on my car again without worrying about it breaking.
  1. trouble codes
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2009, 05:12 PM
  2. SS intercooler and header install = engine codes
    By rascal in forum General Tech Discussion
    Last Post: 09-01-2009, 08:41 PM
  3. Trouble codes
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 09:51 AM
  4. got some trouble codes
    Last Post: 04-10-2009, 10:44 PM
  5. trouble codes
    By BADAZGTP in forum Forum Bugs/Suggestions
    Last Post: 07-26-2008, 10:59 AM
