Thread: Mystery problem with S/C
Results 1 to 7 of 7
Freebeer187 Mystery problem with S/C 02-22-2009, 06:43 PM
Sabrewings Re: Mystery problem with S/C 02-22-2009, 06:46 PM
Freebeer187 Re: Mystery problem with S/C 02-22-2009, 06:47 PM
Sabrewings Re: Mystery problem with S/C 02-22-2009, 06:53 PM
Freebeer187 Re: Mystery problem with S/C 02-22-2009, 06:56 PM
DanGTP Re: Mystery problem with S/C 02-22-2009, 08:31 PM
Freebeer187 Re: Mystery problem with S/C 02-23-2009, 01:08 AM
  1. #1 Mystery problem with S/C
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I was with W-Body guy today to get my LIM gasket taken care of. Good news it that the gasket have been already replaced. The oil is clean and there was not a vacuum leak found. The Supercharger is still "twittering" though. Performance is awful when boost is used. We tried everything we could think of
    Fuel line pressure (50 psi+)
    Remove tuned pcm and installed stock
    plugged BBV valve
    Check wires/hoses (the coolant overflow hose does need to be replaced)
    Checked MAF
    After some scanning the car is running lean. Birkboy would be able to explain this better but for the most part the car is not getting enough fuel.
    The problem is getting worse though. It used to hang a few seconds when using boost but now it just twitters and barely moved.
    Im taking it to a local shop the the fam has been going to for a while tomorrow and let them look at it.
    We are thinking that the car needs tuning to cure, but the fact that we put in the stock pcm with no improvement leaves us confused.
    Any suggestions?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Mystery problem with S/C
    Barksdale AFB, LA
    Sticking fuel injector?
    2009 Subaru Impreza WRX STI
  3. #3 Re: Mystery problem with S/C
    Bartlett, IL
    Seafoam it?
    Well I forgot to add this important detail. The car rides fine (little rough pulse idle at times) without using boost
    How To: E-Brake Pwn
  4. #4 Re: Mystery problem with S/C
    Barksdale AFB, LA
    Some seafoam in the tank would help a sticking injector, if that's the case. No idea for sure.
    Are you getting any misfire codes? Almost seems like an ignition issue.
  5. #5 Re: Mystery problem with S/C
    Bartlett, IL
    Scanned. No misfire
    I have gotten the fuel injectors clean about a year ago. Possible but I do not think it is.
    How To: E-Brake Pwn
  6. #6 Re: Mystery problem with S/C
    Feb 2008
    It's not going to hurt to run some Sea Foam or Lucas Fuel Injector Cleaner through your system. Run it to a half tank instead of a full tank so it will be a bit more concentrated.
  7. #7 Re: Mystery problem with S/C
    Bartlett, IL
    Im going to replace the fuel filter tmw.
    It also could be the NB 02 sensor
    How To: E-Brake Pwn
  1. big problem
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-20-2009, 12:58 PM
  2. Power steering pump mystery
    By cidknee in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:50 PM
  3. Might have a problem.
    By Pontiacman in forum General Tech Discussion
    Last Post: 12-26-2008, 08:57 PM
  4. Mystery Problem, Stalling And More !!
    By 02BlueGT in forum General Tech Discussion
    Last Post: 03-25-2008, 03:53 PM
  5. 97 gp one problem after another
    By vermsta in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2008, 08:44 PM
