Thread: big problem
Results 1 to 7 of 7
  1. #1 big problem
    Dec 2008
    maryland
    ok I just replaced my valve cover gasket, the one under the intake plenum and when I start the car back up it doesnt stay on and i have a puddle of water under the car? please help..
  2. #2 Re: big problem
    Jul 2008
    nj
    huh?? valve cover gasket, upper intake gasket/ supercharger gasket or lower intake gasket?
    If it was the lower intake gasket, check your coolent elbows by the belt tensioner. They break easily
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  3. #3 Re: big problem
    Oklahoma
    Well he posted in the DOHC 3.4L section, so I'll assume for the minute that that is the engine he has and is referring to and if so they are a slightly different beast.
  4. #4 Re: big problem
    Jul 2008
    nj
    O....my bad. Sorry about that. I messed around with a 3.4 not too long ago. My dads impalla has a 3.4 and there is a coolant metal tube that ran across the the front of the engine that we almost forgot. Not sure if you had to mess with that
    FOR SALE
  5. #5 Re: big problem
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    It's the 3.4L DOHC, which is totally different (the top end, anyway) than the 3400 in your dad's Impala.
    The valve cover gasket wouldn't cause a puddle of water under your car. Are you sure you're not referring to an intake gasket?
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  6. #6 Re: big problem
    Dec 2008
    maryland
    yea im sorry i pulled of the plenum again and found that the hose that runs from the fuel pressure regulator to the plenum for vacum pressure was squished, so I replaced that with a regular vacum hose? now it runs but not the way it did before i started. its just at idle its stumbles its not smooth. but the gasket for the plenum is broke, but i dont anymore just yet for another one so i used gasket sealer ? until i can get a new one, is that why its running like that?
  7. #7 Re: big problem
    riverside
    problems are the part of life.
    never worried from these............
  1. How do i fix this problem?
    By thenervemann in forum General Tech Discussion
    Last Post: 11-01-2008, 01:49 PM
  2. Help Problem Please Look!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2008, 12:22 AM
  3. 97 gp one problem after another
    By vermsta in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2008, 08:44 PM
  4. Another HUD problem
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 03-10-2008, 05:51 PM
  5. still got a problem
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-24-2008, 04:36 PM
