You really want the fresh air source after the MAF, but before the throttle plate. After the MAF means that it's metered air, so it's not really a vac leak, and before the throttle plate gets you atmospheric pressure, which is what you need to make the system work. You shouldn't have to mess with that side of the system, though, unless you have it blocked with an IC or an aftermarket TB.
