If you can copy/paste, so can I, right?
Does it make sense? Not really. First, if you take out the PCV Valve, you're gonna have a huge vac leak with a breather. Very bad. Second, if you block off the passages for the PCV Valve, you end up a PCV system that's only partially functional. It'll keep the system from building pressure, but it won't get rid of the corrosive gasses. Third, I'm not even sure what you mean by routing a hose from the breather to a vac source. If you're talking about routing a hose from the neck of the breather, you end up with an even bigger vac leak than I mentioned before.
