Thread: Oxygen sensor fitment issues with headers
Results 1 to 14 of 14
  1. #1 Oxygen sensor fitment issues with headers
    Oct 2017
    South Jersey
    Don't you know I don't read anywhere and don't even think about the upstream sensor as I'm buying and installing my headers. Finally remember I need an o2 on my sd headers, rear one deleted, and the thing won't fit due to my firewall. Has anyone tried a c5 o2 sensor or hammering the firewall with the headers still installed? Installation was really something and I'm not trying to go ahead and disassemble and do it all over again. You speed daddy guys have to know an answer to this one
    Sent from my SM-N920V using Tapatalk
  2. #2 Re: Oxygen sensor fitment issues with headers
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Yup. I guess this is one of those "unspoken" things in the gp community as I had to figure this out myself.
    You have to pound out the fire wall. I did it with headers still installed. Took a socket extension and hammered the crud out of it. Good luck!
  3. #3 Re: Oxygen sensor fitment issues with headers
    Oct 2017
    South Jersey
    Quote Originally Posted by wstefan20 View Post
    You were able to hammer the firewall with the downpipe still in the "tunnel"?
  4. #4 Re: Oxygen sensor fitment issues with headers
    Mar 2017
    Internet
    Somewhere there are tons of pics. Not in that thread though.
  5. #5 Re: Oxygen sensor fitment issues with headers
    I wouldn't say unspoken, it's been well known since like 2011-2012 when they became popular headers.
    Beat the fire wall or install the o2 sensor in the cross over pipe, many do this as well.
  6. #6 Re: Oxygen sensor fitment issues with headers
    Oct 2017
    South Jersey
    So neither of you guys heard of using a c5 sensor?
  7. #7 Re: Oxygen sensor fitment issues with headers
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I haven't heard of a c5 sensor although I ran into the same problem you did. The best option I found was to plug the o2 bung the headers came with and weld in a new bung a little further down. If you don't know how to weld most exaust shops will weld in a bung for about 40$ which is probably cheaper then the sensor your talking about. Idk how big the c5 sensors are but, even if they were an inch shorter id still be nervous about what happens when the motor is jerking around during hard shifts and going WOT that it still might hit the firewall.
    Sent from my LG-H918 using Tapatalk
  8. #8 Re: Oxygen sensor fitment issues with headers
    Mar 2017
    Internet
    Not only did I document it ... I posted tons of pics too. Should have been easy enough to find. I liked to use an air hammer .. takes some finesse, but it's doable and works best for massaging the firewall.
  9. #9 Re: Oxygen sensor fitment issues with headers
    Aug 2017
    Raytown, MO
    Interesting. I've been through literally all the how-to posts and never saw it! Must have looked right past it. Sorry Bill! And no, I hadn't heard of using the c5 sensor, but I had an extra bosch o2 sensor lying around which is why I used it. Lol
    Having another bung welded is a good idea, however keep in mind you can't angle too far down because of condensation. A buddy of mine did this and went through three o2 sensors before he realized his mistake!
  10. #10 Re: Oxygen sensor fitment issues with headers
    Oct 2017
    South Jersey
    So where should I have it welded?
  11. #11 Re: Oxygen sensor fitment issues with headers
    Oct 2015
    Quote Originally Posted by blueanchorgtp View Post
    Anywhere as long as its before the cat. I had it welded into the little u bend although that was a bad idea because I'm lowered and have bottomd it out multiple times to the point where I'm going to have to have that section replaced since its so smashed in.
  12. #12 Re: Oxygen sensor fitment issues with headers
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    This question was answered before you even asked it...look five posts above your post and find FFDP's post.
  13. #13 Re: Oxygen sensor fitment issues with headers
    Mar 2017
    Internet
    FWIW if you are looking for anything I posted in How to, just search on easy and billboost37.
    http://www.grandprixforums.net/threa...ht=easy+header
  14. #14 Re: Oxygen sensor fitment issues with headers
    Aug 2017
    Raytown, MO
    Any muffler shop will weld for cheap. Any place before the catalytic converter will work really. I'd probably do one right before and angled down from the horizontal 30 degrees or so.
    Yeah. I just took the o2 sensor out, grabbed a hammer and some punches I padded with cloth etc. and pounded away! Lol
  1. Oxygen sensor wire extension for headers
    By Tonkin2000GT in forum Wanted To Buy - Parts
    Last Post: 12-29-2015, 04:44 PM
  2. bad oxygen sensor
    By wannabegtp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-03-2015, 11:54 AM
  3. Oxygen Sensor
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2012, 05:50 PM
