Thread: bad oxygen sensor
Results 1 to 9 of 9
  1. #1 bad oxygen sensor
    Jan 2015
    Michigan
    i have a bad oxygen sensor in bank one but i was told not to worry about it. it isnt affecting the performance of the vehicle. does it really need to be replaced? if so how hard is it to do?
  2. #2 Re: bad oxygen sensor
    who told ya that? fix that, the engine will over fuel and clog your cat.
    if you have no cat your wasting gas.
  3. #3 Re: bad oxygen sensor
    Jan 2015
    Michigan
    okay thanks. is it a relatively easy fix? just finding the sensor and replacing it?
  4. #4 Re: bad oxygen sensor
    bank one up stream is in the rear manifold. you need a 7/8 th o2 socket to remove it. HF sells then for like 7 bucks or so.
    whats the code your getting? post it so we are working on the right o2 sensor. you have two. both are bank one. up stream, and down stream is post cat.
  5. #5 Re: bad oxygen sensor
    Massachusetts
    Question: I replaced the upstream O2 sensor at 50,000 miles, just because. I didn't replace the downstream one in back of the cat. Does that one really need to be done?
  6. #6 Re: bad oxygen sensor
    if its not setting a code id leave it. most of the time if its original it wont come out. depending on your year 97-2000 dont really use it, 01 up use it for sure.
  7. #7 Re: bad oxygen sensor
    GTP Level Member
    springfield IL
    I just replaced my downstream this past weekend along with other O2 sensor and spark plugs and wires on my 00' GT... It was stuck in there pretty good and by the time we got it to come out it took to original threads with it so we had to rethread it. It was a pita!!
    I have noticed the car runs a whole lot better along with some better MPG...
  8. #8 Re: bad oxygen sensor
    Massachusetts
    Better mpg in this day and age is always a good thing!
  9. #9 Re: bad oxygen sensor
    Massachusetts
    Thanks Scotty, my model year is 2000 GT.
  1. o2 oxygen sensor
    By brian a in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 08:14 PM
  2. Oxygen Sensor
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2012, 05:50 PM
  3. Oxygen Sensor
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 06-15-2011, 12:55 PM
  4. oxygen sensor
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 06:20 PM
