I have a 2007 Pontiac Grand Prix gt. I have a coolant leak coming down from between the block and transmission. It's coming down on the driver side. I can't seem to see the exact location without taking the transmission from the block. Car starts and drives fine but over heats after a while due to water leaking out. I have checked oil and radiator caps and they are not milky. There is no coolant in the oil also. As soon as I add coolant I look under the car and it's coming out (dripping down) between the transmission and the engine block right off the fly wheel. I have checked the lower and upper imtake gaskets and they are not leaking. I also checked the head gasket and it's not coming from it. I checked the throttle body and it's dry. Would there be a freeze plug or some kind of gasket behind the transmission that would cause it to leak from there.
