Thread: Boost control solenoid filter
Results 1 to 2 of 2
  1. #1 Boost control solenoid filter
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    The little foam filter on my boost control solenoid is falling apart and not filtering anything.
    Can anybody explain how the solenoid works internally? I want to make sure this is an exhaust/vent port. Is it sealed internally in such a way that dirt will not get sucked in the system?
    I am wondering what purpose the filter serves.
  2. #2 Re: Boost control solenoid filter
    It's used for traction control, it can cut boost if traction control is active.
    So many cars have that little foam filter missing, it's basically not even needed. It just helps keep dust and dirt out there if you lived in a climate that was not so nice or took tons of dirt roads.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Replies: 8
    Last Post: 04-07-2014, 06:56 AM
  4. Boost Control Solenoid/EVAP?
    By pski920 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 12:56 PM
  5. boost solenoid
    By tjvdubsport in forum General Tech Discussion
    Last Post: 05-27-2009, 12:24 AM
