Thread: What tables to modify for removing Boost Control Solenoid? (BCS)
Results 1 to 9 of 9
  1. #1 What tables to modify for removing Boost Control Solenoid? (BCS)
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I am planning on removing the BCS from right under the BBV. What tables in HPTuners should I modify for this? Any issues I should be aware of?
    Was just planning on routing the vacuum line from the FPR directly to the BBV.
    Thanks!
  2. #2 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    Why remove it?
    Not like you'd gain anything from it.
  3. #3 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    Mar 2014
    Cincinnati, OH
    I have a bad habit of removing anything in the bay I don't really need. The less computer control, the better! (Doesn't apply in all cases)
  4. #4 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    Dec 2012
    troll land
    Id just remove the solenoid and call it done
  5. #5 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by l67ss View Post
    Think this will cause any issues with the computer? (besides not being able to lower the boost at times when it may want to)
  6. #6 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    Dec 2012
    troll land
    Im using a 99 gtp pcm and an l36 harness on my 97 monte. Harness has no provision for it. Havent had any issues.
  7. #7 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    Mar 2014
    Cincinnati, OH
    Sounds good. I'll prob swap it out and let you guys know if something happens.
  8. #8 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    At most, you might get a CEL
  9. #9 Re: What tables to modify for removing Boost Control Solenoid? (BCS)
    Mar 2014
    Cincinnati, OH
    Yepp, I was looking through all possible CELs last night but couldn't find any in the list... We'll see what happens
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost Control Solenoid/EVAP?
    By pski920 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 12:56 PM
  3. P0243 boost solenoid
    By IllegalIntentions in forum General Tech Discussion
    Last Post: 05-09-2010, 12:54 AM
  4. Boost Solenoid & Fuel Q...
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2009, 02:16 PM
  5. boost solenoid
    By tjvdubsport in forum General Tech Discussion
    Last Post: 05-27-2009, 12:24 AM
