Thread: High negative ltft's
Results 1 to 11 of 11
  1. #1 High negative ltft's
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    What could be the possible cause of high negative fuel trims when I accelerate? The trims sometimes go as high as -14.2, any help or ideas to resolve this would be appreciated.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: High negative ltft's
    Dirty MAF, leaking fuel injector come to mind.
  3. #3 Re: High negative ltft's
    Kemmerer, Wyoming
    could be an o2 sensor as well
  4. #4 Re: High negative ltft's
    Jan 2009
    ny
    I've swapped the Maf with new one and the condition still exists. I also checked the plugs and didn't find any wet ones.
  5. #5 Re: High negative ltft's
    Jan 2009
    ny
    Quote Originally Posted by SgtMarshal View Post
    The 02 sensors only has 4000 miles on it, I'll look into changing it. This condition only happens when I accelerate during normal driving, not when I accelerate hard.
  6. #6 Re: High negative ltft's
    Kemmerer, Wyoming
    probably not an o2 sensor unless you have been using leaded fuel
  7. #7 Re: High negative ltft's
    If your ported throttle body was never tuned for, then that's another thing to look at.
  8. #8 Re: High negative ltft's
    Jul 2017
    MN
    Quote Originally Posted by kissmyss View Post
    Something causing your fuel pressure to go to high under WOT. Rare, but possible.
  9. #9 Re: High negative ltft's
    Jan 2009
    ny
    It was tuned for the tb, I've had it for over 8 years and this just started happening.
  10. #10 Re: High negative ltft's
    Jan 2009
    ny
    Quote Originally Posted by Toys4life C5 View Post
    The conditions happen under mild acceleration from stop, during wot the trims lock at 0.0
  11. #11 Re: High negative ltft's
    any chance you just had the battery unhooked in the last day or so when this started? cause it sounds like your trims are re learning maybe. locking in at 0.0 wot only happens when the trims are learning still, ive yet to see a tune hit 0.0, always one way or the other once learned. and it seems like you got a canned tune, so no way the trims hits 0 wot when it learned.
  1. Negative LTFT, Knock Retard advice.
    By FunGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2016, 05:57 PM
  2. Negative LTFT from P0107/MAP?
    By Centauri in forum General Tech Discussion
    Last Post: 05-02-2015, 03:49 PM
  3. 3800 sc high ltft
    By hollas13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2015, 07:03 AM
  4. Negative LTFT and resettting trims.
    By industrialfish in forum General Tech Discussion
    Last Post: 01-18-2015, 10:07 PM
  5. Likely cause of high LTFT's
    By jims05ss in forum General Tech Discussion
    Last Post: 05-06-2009, 12:35 PM
