Thread: Injector oulsewidth drops after 5700 rpm
Results 1 to 14 of 14
  1. #1 Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    So I recently did a topswap on my 2005 Buick Allure, and it runs real good. But for aome reaaon my injector pulse width just drops after 5700 rpm in WOT. I dont feel like its a sensor issue, and if I try to command more fuel it still just drops. This is causing leaning out. I checked the fuel pressure while going into WOT. It stays at 58-60 psi. I do have 60lb injectors in right now. I dont know if there is a bad ground or something else going on. Any ideas on where to start my diagnostics?
    Sent from my SM-G920W8 using Tapatalk
  2. #2 Re: Injector oulsewidth drops after 5700 rpm
    What software are you using to tune?
    If it's HP Tuners, looking at the log would be helpful for me as I have that software.
  3. #3 Re: Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    I have hp tuners, ill load up a log
    https://www.dropbox.com/s/5s5pz0r5ep...%20PW.hpl?dl=0
  4. #4 Re: Injector oulsewidth drops after 5700 rpm
    Post the tune file as well.
    Remove the 1 bar map channel and replace it with the 2 bar map channel so you can read boost in the scanner. I'm assuming you are running a 2 bar map. Something seems off if your wideband is correct. You are commanding 12's but your wideband it always in the 13's at WOT.
  5. #5 Re: Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    Here is the tune I currently have uploaded to it. I tried running a 2 bar map sensor, but it does not work. Car runs like **** and is hardly drivable. https://www.dropbox.com/s/m99bl1l4y0...0%20e.hpt?dl=0
  6. #6 Re: Injector oulsewidth drops after 5700 rpm
    So adding like 5% to the MAF curve up top hasn't helped with it leaning out?
  7. #7 Re: Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    Ill try that next, it just looks like the injector pulse width just drops
  8. #8 Re: Injector oulsewidth drops after 5700 rpm
    The pulse width drops from like 9 to 7.5 but the o2 sensor drops from 900 down to 50.
  9. #9 Re: Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    Ya, so I dont know. Ill do that and check my fuel pressure again while doing it. See how ot works out
  10. #10 Re: Injector oulsewidth drops after 5700 rpm
    http://www.grandprixforums.net/threa...ht=swap+sensor
    Read the last post about why your 2 BAR map may not have worked for you.
    These computers are so limited on what you can change and watch because they have so little data. But I could see an issue with the baro/map going screwy and causing it to lean out as it doesn't know exactly what is going on.
  11. #11 Re: Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    You talking about the baro sensor?? I will look into getting a second sensor setup for it. I dont know of its because the GTP has two map sensors or what. I didnt think my car had a baro, but I can read it.
  12. #12 Re: Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    So I added some fuel up top. And it did not help any. Injector pulse width still goes from 9 to 7 during WOT. Any other ideas?
  13. #13 Re: Injector oulsewidth drops after 5700 rpm
    try turning the injector flow rate up top? get the right map on there yet?
  14. #14 Re: Injector oulsewidth drops after 5700 rpm
    Jun 2017
    Alberta
    Ya ive got a single bar map which is what the pcm ran with originally. I was thinkimg of making the fuel injectors smaller seeing if that would help.
  1. 4T65E-HD RPM Drops
    By Felix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-29-2016, 10:02 PM
  2. temp goes to right below red and then drops to 180
    By csanderlin in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-08-2013, 01:11 AM
  3. Tach drops to zero
    By ahill261 in forum General Grand Prix Discussion
    Last Post: 10-05-2012, 10:11 PM
  4. RPM drops above 45 mph
    By guyute85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2011, 01:58 AM
  5. rpm drops
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2011, 06:16 PM
