IDK im not very good at zeroing in on a issue but if you have put 2 sensors in and still getting a code and it runs ok for 2 second spurts then i dont think the cam sensor is the issue. However I cant tell you what is either.
I would post the other codes you have and Scotty or FFDP or another member with similar exp will be able to help you im sure
