Thread: po341 cam sensor circuit code
Results 1 to 12 of 12
  1. #1 po341 cam sensor circuit code
    Apr 2009
    stockton ca
    Got it all buttoned up fired her up was filling it with water and a po341 code poped up Just curious if this could be simple or a common problem
    I have the gm diagnostic walkthrough but im sure others on here have encountered this....
  2. #2 Re: po341 cam sensor circuit code
    Apr 2009
    stockton ca
    no luck i guess looks like aq long day of diag
  3. #3 Re: po341 cam sensor circuit code
    Apr 2009
    stockton ca
    I have no clue drove it home today after replacing the cam position sensor and its real rough and shaky and the po341 code popped up again looks like a fun weekend and i dont have all the schools toys to diag with
  4. #4 Re: po341 cam sensor circuit code
    Apr 2009
    stockton ca
    Looking for opinions here
    I was reading about the code and it says the computer will take over for the cam position sensor but its a 1 in 6 chance it works right so does this mean if i restart the car 6 times i should get it to run right at least once right???
  5. #5 Re: po341 cam sensor circuit code
    Charles City, IA
    Just follow the flow chart you get from alldata or shop key and you will find your problem.
    SMGPFC Two Nipple General
  6. #6 Re: po341 cam sensor circuit code
    Charles City, IA
    I can get you one if you need it.
  7. #7 Re: po341 cam sensor circuit code
    Apr 2009
    stockton ca
    Ya im working off si2000 the gm site but its a long chart to follow and unless im getting paid i get lazy lol I just need it to run good enough to get to my buddys shop and thats like 20 miles away Ive tested the coil packs and wires i guess im pulling the pcm and icm tomorow
    I put a new can sensor in it last thurs so im pretty sure its a conection issue or short to ground
  8. #8 Re: po341 cam sensor circuit code
    The car will run perfectly normal with this code. So your running is probably something else...check vacuum as it's usually the issue.
    Being a new motor, and new timing gears.. Did you swap the cam gear magnet onto the new gear? If you had helpers and are unsure you can take out the cam sensor and stick a finger in to feel for it while someone slowly turns the motor by hand. If you suspect the wiring, it's pretty quick and easy to swap. I have 4-5 spares laying around. Holler.
  9. #9 Re: po341 cam sensor circuit code
    Apr 2009
    stockton ca
    I put the magnet in right before i put on the front cover and we put in a new sensor what it was saying is the computer will take over for the sensor but its a 1 in 6 chance and ive actually seen what it means one time i started it it ran smooth a couple more time it was rough
    All the vacuum is good i had it hooked up to my laptop and its only showing the cam code
    and map looks good and all readable sensors look fine engne vacuum was fine as well
    I just dislike the electrical side of things testing and so on
  10. #10 Re: po341 cam sensor circuit code
    Charles City, IA
    Just throwing it out there. Check the ground for the ICM. It will make your car run like **** if it is not goo.
  11. #11 Re: po341 cam sensor circuit code
    Apr 2009
    stockton ca
    Thats the only ground on that part of the harness right? if so I have it hooked up even changed spots for it
    My one thought is that the head where its grounded to may be a bad ground due to the gaskets and the sealant on the head bolts
    Either way cars going into a buddys shop on monday he will help me diagnose and then ill fix it my self
  12. #12 Re: po341 cam sensor circuit code
    SE Level Member CityStarz's Avatar
    Nov 2009
    pittsburgh PA
    i knocked my cam interupt out of place installing the front cover the first time. it's not hard really, all i did was bump it
    take the sensor out, get a mirror/flashlight and slowly rotate the motor until you can visually verify that it's still there. mine was there, but i bent the tabs and it got pushed back
    check the harness wires where they run behind the waterpump pulley. it's also common for the pulley to chew through those wires if the harness is not routed correctly
    L36|Topswap|3.25|NIC cam|JP Double|Comp 105s|SLP Headers|Full stainless 3" to 2.5" Y|Fully Ported Blower|ST2 TB|FWI|PT|LC-1
  1. Crank sensor code thrown
    By Risinnfallen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 02:00 AM
  2. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
  3. what is on the horn circuit?
    By Bio248 in forum General Tech Discussion
    Last Post: 11-25-2008, 01:05 AM
  4. P1810 Trouble Code - TFP Valve Position Switch Circuit
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2008, 11:03 PM
  5. Circuit city install in a civic
    By archemedes in forum Off Topic Discussion
    Last Post: 04-05-2008, 09:23 AM
