Thread: Engine problem
Results 1 to 20 of 23
  1. #1 Engine problem
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    2002 gtp 109000 miles.
    I'm sitting stranded waiting for a ride 200 miles from home thought I would ask a few questions.
    I was nearly halfway along on a road trip 65 mph climbing a hill and heard a light rattle. It wasn't pinging more like plastic rubbing on something. I shifted into different gears and neutral and reved the motor. Sound was rpm dependent in neutral. Then oil light came on and I killed the engine. I coasted off the road. Checked things out. Car wouldn't crank over, like it's seized. Oil has flecks of metal in it. Before I left home oil was super clean.
    I'm pretty certain the motor has to come out. I'm betting on a spun bearing but I don't know of common issues with this engine. When I get the car home I'm gonna try turning the crank by hand maybe pull valve covers.
    I'm looking for tips , or places to find them on specific issues to look for. Interested in rebuild books on this engine or if factory service manual is adequate. Also any tips on gaskets or piston kits. Things to do while motor is out? Best way to pull motor, subframe or out the top-no lift, garage method.
    I have experience doing a tear down rebuild on a Ford 460 with some supervision. Would like to hear from anybody from those with any range of experience.
  2. #2 Re: Engine problem
    Sounds like it's junk.
    If it spun a bearing and you have metal flakes in the oil you are better off just getting a different motor. It is not cost effective you rebuild a 3800 with how much machine shop work is required. Also if the crank is damaged from a spun main or rod bearing, it's going to cost even more.
    Bearing failures are fairly common, between that and intake gasket failure. Like 7-8 years ago with my first 97 GTP, I took a 90 mile road trip to our cabin and the rod knock started as I pulled into the driveway. Happened out of the blue and that was that for that motor/car.
  3. #3 Re: Engine problem
    May 2017
    Dirtyzville, Mizzery
    Find a used motor; yank it apart minus the short block...re-gasket everything, but if your top end is good; just re-use that. Pretty easy to work on these things too. Only thing you really have to worry about on a bone stock car is the downpipe bolts snapping since it's so old, and the b1tch bolt that's goes into the bell housing backwards under the rear manifold. You can get it with like 5,765 feet of extension thru the passenger wheel well. There is also a goofy transmission brace on the passenger side as well that bolts the engine and trans together.
    Can be done with simple hand tools, and an engine hoist. Just un-bolt the hood, remove the dog bones, and you'll have all the room/movement you'll need.
    I'd also replace things like the motor/trans mounts, have the cylinder heads gone through at a machine shop, have the lower intake hot tanked...and if you want, I'd reseal the supercharger with new anerobic sealant, put a new coupler/fluid in there and scrub out the throttle body as well. You'll basically have a brand new engine top to bottom with used parts.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  4. #4 Re: Engine problem
    Jul 2011
    Eastern Idaho
    Kind of what I thought. I will get a used motor, and regasket it. Probably check rod and crank bearing clearances.
    Any idea why the common bearing problems? Good donor cars? Like Buick/elderly driven.
  5. #5 Re: Engine problem
    Don't even open up the used motor. If you remove any rod bearing cap or main bearing cap it has to go to a machine shop. It's not like an old 350 or small block ford, these engines like twist when something is removed.
  6. #6 Re: Engine problem
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Un related to your issue specifically, I had a 2000 n/a GP that ran like a top. Never a lick of trouble. Then one day right as I let off the gas, to go down an off ramp, It stumbled and would barely idle. I figured it was a bad sensor or something else not very serious, so I limped it home. Turns out it broke an intake valve spring, letting the valve drop and bounce off the piston about 60,000 times. Fluke thing... just let go....
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #7 Re: Engine problem
    May 2017
    Now that I think of it; Idaho is far...but if you strike out on engines I have a fully studded and balanced rotating assembly I had built a few years back for a huge turbo car that I never used. I could take out the head studs and you could literally put all the stock parts on it. The rest of the car should fall apart before that motor would quit working LOL. L32 pistons and rods (from the '04+ GTP's), ARP Main Studs, brand new bearings throughout. Block has been decked for a little more compression but not enough to affect anything on a stock car. I'd always suggest putting a downpipe in there though while the engine is out if you plan on keeping it. It's the most restrictive part of the car. ZZPerformance sells a nice bolt in catted or catless unit that hooks up right to the stock catback.
  8. #8 Re: Engine problem
    Jul 2011
    Eastern Idaho
    I phoned a friend and avoided a $800 tow bill and rented a uhaul to tow home. I unloaded the car in the garage and cut open the oil filter. It is full of bearing material (non magnetic). I bought the car 49 days and 2655 miles ago. I believe the car has a 90 day 3000 mile warranty. I am calling the dealer ASAP talk about what they are going to do about it.
  9. #9 Re: Engine problem
    May 2016
    Rouge Island
    Give 'em Hell.
  10. #10 Re: Engine problem
    Jul 2011
    Eastern Idaho
    Got the engine pulled yesterday and on a stand. The rear/driverside cylinders had 1 piston with wrist pin pulled out of the piston. the next had a spun bearing and broken connecting rod. All the parts were rattling around when I turned it over on the stand. Other signs point to poor maintenance maybe lack of oil changes and low octane fuel used. Bearings are banged up a bit. Motor only has 109000. When I pulled the oil filter extension it had a bunch of grease sludge in the passages. I don't think it starved of oil because of it.
    So the search is on for a used replacement. My thoughts are as follows...
    low mile = less than 100,000 miles.
    Low mile 97-03 L67?
    Low mile L36 and top swap? (I don't know what would need to be done beyond physically swapping top end such as programming etc please advise)
    Low mile 04-07 L32 (I like this idea because of more efficient gen 5 M90, if I can make it work. Can I use my throttle body on this motor? What else might be involved)
    What would you do? Car will be used for daily commuting and is definitely worth repairing as far as condition goes, would like more power while maintaining reliability.
    I called the dealer. I signed an as is legal document apparently. They said they specifically try to avoid selling cars with detectable issues and auction those off if they get them. Basically said I am screwed but offered to provide some labor assistance if I was closer. As an alternative the guy said he will have a staff meeting on monday to see if they can offer financial assistance.
  11. #11 Re: Engine problem
    Jul 2011
    Eastern Idaho
    Quote Originally Posted by blueguy91 View Post
    What is your location? I might consider your offer. Please send me a PM with price.
    When you say hot tank the lower and reseal the supercharger are you saying something like clear coating the outside or recoating rotors?
  12. #12 Re: Engine problem
    you'l need to start shopping around for whats out there local to you, then make up your mind as to a top swap or not.
  13. #13 Re: Engine problem
    Jul 2011
    Eastern Idaho
    I have been shopping around but for L67s. So I am curious what is involved in the other options. If its doable then I will expand my search a bit.
  14. #14 Re: Engine problem
    top swap, or a bottom swap in your case as well as mine, you just use the short block of a na 3800. bolt on the balancer, heads lim and blower from the old engine on it.
  15. #15 Re: Engine problem
    Jul 2011
    Eastern Idaho
    Is it necessary to check the fuel map or do they run well without programming work?
  16. #16 Re: Engine problem
    no idea what that is.
    all your doing is using a higher compression bottom end. headers should be installed as well to help let it breath better. stock tune from your gtp should work fine, or get a tune to get the most out of it.
  17. #17 Re: Engine problem
    Jul 2011
    Eastern Idaho
    A replacement L67 with 98k is on order along with misc parts. I am going to check the bearings when I get it and regasket everything except head gaskets due to tty bolts and maybe main seals. I need to do more research but I do not believe the rod and main bolts are torque to yield( dealer doesn't think so) and I would be stupid not to check the bearings in my opinion. Convince me otherwise if that is a bad idea.
    Dealer ship might help me out but still waiting for confirmation.
  18. #18 Re: Engine problem
    dont check anything in the bottom end if you want it to run still. open them bearing caps and its junk. re gasket it all but the heads install new rear main seal and rear cover gasket, clean and paint it nice if you care to.
  19. #19 Re: Engine problem
    It's not about being TTY or any of that stuff.
    There are three basic reasons for line boring the main bearing and cam bearing bores in engine blocks. One is to restore worn, out-of-round or damaged bores. If an engine overheats or loses oil pressure, one or more bearings on the crankshaft or camshaft may seize and spin. The resulting damage to the bearing bore must then be repaired by either machining the hole to accept a standard sized bearing or an oversized bearing.
    With main bearings, a worn, out-of-round or damaged bore can be restored back to standard ID by grinding or milling the mounting surface of the main caps, bolting the caps back on the block, and then cutting the holes back to their original dimensions.
    In the case of worn, out-of-round or damaged cam bearings in an engine block, there are no removable caps. The only option is to enlarge the bores so new oversize cam bearings with a larger outside diameter (OD) can be installed.
    Reason number two for line boring a block is to restore proper bore alignment – a process which is often called "align" boring (or honing if a line hone is used instead of a boring bar). As rigid as an engine block might seem, there is actually quite a bit of residual stress in most castings. As a new "green" block ages and undergoes repeated thermal cycles, the residual stresses left over from the original casting process tend to distort and warp the engine. This affects the alignment of the crankshaft and camshaft bores as well as cylinders. Eventually things settle down and the block becomes more or less stable (a "seasoned" block). The bearings as well as the crankshaft and camshaft journals gradually develop wear patterns that compensate for the distortion that has taken place.
    Additional warpage can occur if the engine is subjected to extreme stress (like racing) or overheats. If the original crankshaft or camshaft is then replaced without align boring the block, it may bind or cause rapid bearing wear. Likewise, if you’re building a high performance engine with close tolerances, you don’t want any misalignment in the main bores or cam bores.
    The third reason for line boring or honing a block is to correct or change bore centers or bore alignment (as when "blueprinting" a high performance engine). The camshaft and crankshaft should be parallel in the block. If they are not, line boring can correct the misalignment to restore the proper geometry. With performance engines, there may also be a reason to change the centerline of the crankshaft or camshaft slightly to alter the piston or valvetrain geometry.
    This is really why, once the caps are removed you are now in a way ruining what was once a properly aligned motor.
  20. #20 Re: Engine problem
    Jul 2011
    Eastern Idaho
    The way I read that is that line boring is required and bearing bores need aligned before bearing shells are installed into an engine that has had distress...
    Please explain, what does this have to do with removing and reinstalling bearing caps in an engine without distress as along as you follow the correct procedures for installing the caps such as torque procedure. The information quoted above doesn't explain why removing and reinstalling a cap would cause misaligned engine bearing bores. Caps are specific to the block/rods they are mated with and machined together. It only says line boring should be done for replacement work or rebuild work which I agree with. But simple replacement or inspection of bearings and nothing else I am not convinced is wrong or risky to the life of the engine.
    Don't get me wrong here, I do not want to harm my engine. I want it to last as long as possible trouble free. I think it would be stupid not to look at a couple of bearings and decide if its worth installing in the car without new bearings. Please explain further why a 3800 is different than any other motor. I have done this same thing with other engines and had zero problems. Are there any reputable references that you guys know about regarding this?
  1. 2000 Grand Prix with series 1 Engine, Weirdest engine problem ever!
    By ElectricBlake in forum Introductions/Noob Questions
    Last Post: 01-19-2016, 12:15 AM
  2. is it an engine problem or transmition?
    By monkey man in forum General Tech Discussion
    Last Post: 02-07-2015, 12:41 AM
  3. Engine Problem...
    By Lowdown112 in forum General Grand Prix Discussion
    Last Post: 01-05-2013, 06:42 PM
  4. Help! Engine problem
    By Barry67 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2012, 08:26 AM
  5. Engine problem???
    By WHITEHORSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:11 PM
