Thread: boost leak from rod coming out of supercharger
Results 1 to 7 of 7
  1. #1 boost leak from rod coming out of supercharger
    Kemmerer, Wyoming
    Is it Possible to have a boost leak from the rod that comes out the supercharger at the Boost bypass valve?
    https://drive.google.com/file/d/0B6KoWYZT_pmCQW9PdFJOZGtrUUk/view?usp=sharing
    https://drive.google.com/file/d/0B6K...ew?usp=sharing
  2. #2 Re: boost leak from rod coming out of supercharger
    May 2017
    Dirtyzville, Mizzery
    If the plunger in it is dry rotted, then sure.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  3. #3 Re: boost leak from rod coming out of supercharger
    Kemmerer, Wyoming
    I think I figured it out, I don't have the car back together yet, so I'm not exactly sure, but I think the bbv wasn't adjusted correctly so it couldn't close all the way.
  4. #4 Re: boost leak from rod coming out of supercharger
    May 2017
    You can move it around all you want; that doesn't impact anything. ZZP used to tell you to unbolt them and lower them for "better performance", which was a load.
    If it works, it works. If it doesn't, oh well. You'll lose an MPG or two.
  5. #5 Re: boost leak from rod coming out of supercharger
    Mar 2017
    Internet
    Agree with BlueBalls.. if the diaphragm is bad.. it's leaking. Put on a fresh one.
  6. #6 Re: boost leak from rod coming out of supercharger
    Kemmerer, Wyoming
    nothing wrong with the actual bbv, it was how it was bolted on to the supercharger, like how zzp said you can lower it for "better performance", I did that once and lost at least 1 psi of boost because the valve couldn't close all the way.
  7. #7 Re: boost leak from rod coming out of supercharger
    May 2017
    So is the rod that goes into the plunger, bent?
    Send me a picture of it, Marshall.
  1. Maf code now I have a vac leak coming from my intake
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2014, 02:01 PM
  2. Vacuum/boost line coming off blower
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 03-02-2014, 05:30 PM
  3. Don't know where my coolant leak is coming from?
    By sseigtp in forum General Grand Prix Discussion
    Last Post: 08-17-2012, 01:59 PM
  4. cant figure out where this leak is coming from.
    By Drews in forum General Tech Discussion
    Last Post: 03-22-2012, 04:48 PM
  5. I have an antifreeze leak coming from the intake
    By lzicc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2010, 01:36 PM
