Thread: LIM PCV mod vs breather
Results 1 to 20 of 20
  1. #1 Re: LIM PCV mod vs breather
    Quincy, Mass
    Quote Originally Posted by sseilmnop View Post
    The groove takes the vacuum out where it can go through the intercooler without hitting the core.
    There isn't vacuum available under the groove, your above intake air cylinder 1 at that point.
    Thank you that's what I was wondering.
    So the wbs ic front pcv will work with a zzp groved lim? Or the wbs core is too big for it to work?
    No more GP 04 Impala SS Indy:
  2. #2 Re: LIM PCV mod vs breather
    Mercer, Pa
    Quote Originally Posted by Swiggles View Post
    WBStore Intercooler won't work with ZZP groove manifold. You can't make it work with it either. You most go external route.
    Both Intercoolers use the same core! They are probable machined on the same machine.
  1. Installed Intercooler.. Breather or not??
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 10-14-2016, 03:34 PM
  2. Using a breather with an intercooler
    Last Post: 10-04-2014, 06:38 PM
  3. oil in valve cover breather
    By silver3 in forum Turbo
    Last Post: 10-01-2013, 09:44 PM
  4. Valve cover breather ?
    By mikey666 in forum General Tech Discussion
    Last Post: 05-02-2013, 07:17 AM
  5. How to take rock breather out of s/c shaft?
    By ItHurtz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2012, 07:08 AM
